How to specify custom solid colors that persist?
I find myself constantly adding custom colors to the Pick Solid Color dialog, since it doesn’t seem that these colors persist across sessions.
For example:
  1. Launch fresh session of ParaView 6.1.0 (make sure it’s the only open instance of ParaView).
  2. Create sphere source
  3. Click the Edit Color Map button while coloring by Solid Color
  4. Click on the bottom left Custom colors box, enter #F04562 into the HTML field, click the Add to Custom Colors button.
  5. Click the OK button to close the dialog.
  6. Close ParaView
  7. Open ParaView and repeat steps 1-3. The custom color is back to white.
Is there a file somewhere I can modify? Doesn’t seem like this is in the ParaView-UserSettings.json and Claude suggests that this is a QT setting and, as such, is hidden from users.
Client Information:
Version: 6.1.0
VTK Version: 9.6.1
Qt Version: 6.9.0
vtkIdType size: 64bits
Embedded Python: On
Python Library Path: C:\\Program Files\\ParaView 6.1.0\\bin\\Lib
Python Library Version: 3.12.7 (tags/v3.12.7:0b05ead, Oct  1 2024, 03:06:41) \[MSC v.1941 64 bit (AMD64)\]
Python Numpy Support: On
Python Numpy Path: C:\\Program Files\\ParaView 6.1.0\\bin\\lib\\site-packages\\numpy
Python Numpy Version: 1.26.4
Python Matplotlib Support: On
Python Matplotlib Path: C:\\Program Files\\ParaView 6.1.0\\bin\\lib\\site-packages\\matplotlib
Python Matplotlib Version: 3.7.2
Python Testing: Off
MPI Enabled: Off
ParaView Build ID: superbuild af9bb3207d40b64f97c64a9c319d483ff3b17d03 (!1332)
Disable Registry: Off
Test Directory:
Data Directory:
SMP Backend: TBB
SMP Max Number of Threads: 32
OpenGL Vendor: NVIDIA Corporation
OpenGL Version: 3.2.0 NVIDIA 596.59
OpenGL Renderer: NVIDIA RTX A2000 12GB/PCIe/SSE2
Connection Information:
Remote Connection: No
Hmm, yeah, I would expect those colors would be saved in the Qt .ini file alongside the ParaView-UserSettings.json file (~/.config/ParaView/ParaView.ini on linux and macOS), but that doesn’t appear to be the case. It looks like an oversight because the color chooser dialog is created as needed for a color selection, and likely no one thought to save that dialog’s state along the way.
I think it makes sense to save those custom colors across sessions. Mind creating an issue for this?
Done, see https://gitlab.kitware.com/paraview/paraview/-/work_items/23321
Thanks!
