How to write AMR grid in Catalyst-5.6
I asked this a week ago, but did not get any feedback. Let me try to clarify my question. I build CatalystExamples. Running “CxxNonOverlappingAMRExample feslicescript.py” works as expected, I get slice_#.vtm files.
But how to write the grid? Using SampleScripts/gridwriter.py fails with “AttributeError: ‘PVModule’ object has no attribute’‘XMLHierarchicalBoxDataWriter’”. I have the same issue with CxxOverlappingAMRExample, slice works, grid does not.
I work with Catalyst-v5.6.0-Base-Enable-Python-Essentials-Extras-Rendering-Base on Linux x86_64.
Any help is highly appreciated.
Thanks,
Ted
./CxxNonOverlappingAMRExample gridwriter.py
File “”, line 2, in
File “gridwriter.py”, line 99, in DoCoProcessing
File “/ascldap/users/tesari/local/catalyst/lib/python2.7/site-packages/paraview/coprocessing.py”, line 212, in UpdateProducers
self.CreatePipeline(datadescription)
File “gridwriter.py”, line 55, in CreatePipeline
File “gridwriter.py”, line 17, in CreatePipeline
adaptorinput = coprocessor.CreateProducer( datadescription, “input” )
File “gridwriter.py”, line 37, in Pipeline
filename = 'input
%t.vthb’
AttributeError: ‘PVModule’ object has no attribute ‘XMLHierarchicalBoxDataWriter’
@Dave_DeMarle @cory.quammen @utkarsh.ayachit This is for a user of mine.
Thanks guys!
Hi Tim and Alan.
In your copy of gridwriter.py, please try and substitute XMLUniformGridAMRWriter for XMLHierarchicalBoxDataWriter.
@Alan please file a bug report and assign it to me.
No difference:
  AttributeError: 'PVModule' object has no attribute
‘XMLUniformGridAMRWriter’
Thanks,
Ted
  [ews00734@CxxOverlappingAMRExample $] ./CxxOverlappingAMRExample
gridwriter.py
adding in script gridwriter.py
File “”, line 2, in
File “gridwriter.py”, line 100, in DoCoProcessing
    File
File “gridwriter.py”, line 56, in CreatePipeline
    File "gridwriter.py", line 17, in _CreatePipeline
“input” )
File “gridwriter.py”, line 38, in Pipeline
filename = ‘input_%t.vthb’
File “”, line 2, in
    File
“input” )
My next idea is that these particular writers are scrubbed away and not available in the catalyst editions. This appears to be done by the files Extras/manifest.json which selects a subset of the readers and writers in the VTK/IO/XML directory to make available.
When I use gridwriter with either overlapping or nonoverlapping example against a full paraview build, gridwriter finds the original XMLHierarchicalBoxDataWriter just fine.
You should either use a full paraview build as the catalyst library to link against, or extend your edition via that manifest file to include the writer.
Hi Dave,
  I have a clean build of Paraview. When trying to build the
examples, I get error (attached): 'Found paraview-config.cmake, but ParaView is considered to
be NOT FOUND", and ‘Could not find
vtkPVPythonCatalyst’.
vtkPVPythonCatalyst files are available
under lib64:
./lib64/python2.7/site-packages/paraview/modules/vtkPVPythonCatalyst.py
./lib64/python2.7/site-packages/paraview/modules/vtkPVPythonCatalystPython.so
    ./lib64/vtk/hierarchy/ParaView/vtkPVPythonCatalyst-hierarchy.txt
    ./include/paraview-5.6/vtkPVPythonCatalystModule.h
  I haven't work with the full build of Paraview before. What do I
miss?
Thanks,
Ted
[ews00734@build $] ./my_catalyst_build
– Boost version: 1.53.0
CMake Error at CMakeLists.txt:8 (find_package):
Found package configuration file:
/ascldap/users/tesari/local/catalyst/lib64/cmake/paraview-5.6/paraview-config.cmake
    but it set ParaView_FOUND to FALSE so package "ParaView" is
considered to
be NOT FOUND. Reason given by package:
    Could not find the ParaView package with the following required
components:
paraview-config.cmake (6.64 KB)
I set mine to my 5.6.0 build directory.
ParaView_DIR:PATH=/home/demarle/Source/PARAVIEW/devel/release_5.6.0/build
Where it found the attached paraview-config.cmake.
ParaViewConfig.cmake (5.0 KB)
Hi Dave,
I set ParaView_DIR to my build directory, but still get 'Found paraview-config.cmake,
but ParaView is considered to be NOT FOUND. Next, I did
a fresh clone from gitlab.kitware.com/paraview/paraview.git
(c5c6c48237276), - same error.
In my humble opinion, find_package(ParaView) fails,
because it looks for UseParaView.cmake, but there is no file
matching UseParaView* in the paraview trunk.
Next, I try to add XMLUniformGridAMRWriter
in Extras/manifest.json (XMLHierarchicalBoxDataWriter
is already included). As a first step I made a copy of Base as
myBase, and run catalyze.py:
    [ews00734@Catalyst $] python catalyze.py  -r
/ascldap/users/tesari/projects/paraview -i Editions/myBase -o
~/projects/myBase
    Processing  Editions/myBase
    patching file ParaViewCore/ClientServerCore/Core/CMakeLists.txt
    Hunk #1 FAILED at 34.
    Hunk #2 FAILED at 48.
    Hunk #3 FAILED at 108.
    3 out of 3 hunks FAILED -- saving rejects to file
ParaViewCore/ClientServerCore/Core/CMakeLists.txt.rej
    can't find file to patch at input line 33
    Perhaps you used the wrong -p or --strip option?
    The text leading up to this was:
