Hi there!
I’ve been searching for a way to hide an entry in an enumeration domain of property A when property B is false, for example.
Is there any way to do this using pure xml?
Thank you!
Patrick Laurin
Hi there!
Thank you!
Patrick Laurin
Not doable with XML only. You need to use a StringListDomain and an associated information property that will query the available string server side.
There is a few example in the Example Plugins of ParaView.
