Inplane Streamlines Dean Vortices Error
Hello ParaView Community,
I am trying to visualize in-plane streamlines on a cross-sectional slice of a pipe in ParaView, but I keep running into errors regardless of the filter pipeline I use.
My Setup is OpenFOAM-13 / Build: 13-cde978a97c9
My goal is to create streamlines from a simple s-bended pipe on a 2D Slice (Y-Z plane) to visualize vortices/secondary flow.
Like here:
[Source: Dean vortices in turbulent flows: rocking or rolling? | Journal of Visualization | Springer Nature Link ]
My current pipeline:
  1. Slice (Normal: 1 0 0, Origin: inside the pipe)
  2. Surface Vectors (Select Input Vectors: U, Constraint Mode: Parallel)
  3. Cell Data to Point Data (to ensure point data for the tracer)
  4. Stream Tracer (Vectors: U, Seed Type: Line or Cloud I tried both which failed)
The error which results is: ERR| vtkPStreamTracer: Bad velocity array.
I think my velocity array is falsely defined. But I cant get it to work.
Thanks in advance for your help!
Please share your data.
realGasTube.zip (3.5 MB)
In this zip there is the .cgns file. :slight_smile:
like that ?
stream.pvsm (643.9 KB)
Thanks a lot (especially for the fast answer),
How can I adjust the density/resolution of the lines. I know there is a field in the normal StreamTracer Filter, but I cant find it with the CustomSource StreamTracer or ConvertToPointCloud Filter. And is there a possibility to recreate also the arrows with the corresponding direction.
I tried to recreate it (without state file), but it doesnt work. Is there any special setting for ConverttoPointCloud or StreamTracerwithCustomSource (Input=Slice1 and Seed=ConvertToPointCloud1)
:slight_smile:
By reducing the number of seed, you can use MaskPoints for that.
Add a Glyph filter.
Nothing special, you can send your state file here if you want me to take a look.
Thanks!
Maskpoints works in your state file.
But I cant get it to work with the same procedure as shown in your file. Is there any flattening of vectors?
My state .pvsm is attached
stream_dean_vortex.pvsm (555.1 KB)
Your state file is corrupted but I was able to identify that you need to enable “Surface Streamlines” on the stream tracer.
