I have a uniform rectilinear grid of 862x759x1526 and try to contour a point data array “density” of 1-component float32s. With paraview 5.11.1 (official binaries) and the VTKmFilters plugin loaded: applying the VTK-m contour filter reports Input dataset/parameters not supported by vtkmContour. Falling back to the default VTK implementation..
This is a bit surprising given that the dataset isn’t very exotic. Is the VTK-m contour filter more limited in the type of inputs it can handle? And, if so, what’s the limitation in this specific case?
Detailed dataset properties:
