Hello. An error itself suggests that there is a compatibility problem with your system’s libSM.so (X11 related) library (there is a function that cannot be found in this library).
Your distribution is quite new so I think that only developers will give you the correct answer (on old distributions there may be just missing/incompatible-arguments functions in old libraries so you can solve the problem with updating your OS). But if you only need the standard ParaView, you can use official binary version from ParaView site (compiling usually needed for non-standard use-cases like Catalyst).
