fashing
(fashing)
September 8, 2023, 2:56am
1
Hi, I am using Paraview 5.11.1 for volume rendering. And the testcase I use contains multiple grids in Grid Arrays. I notice that I can only choose one grid each time in the coloring select. I wonder if there’s a way to show multiple / all grids in one time? It’s even better if we can customize the color for each grid!
(the coloring select I mentioned)
Thank you for your time!
mwestphal
(Mathieu Westphal (Kitware))
September 8, 2023, 7:19am
2
Here are two blog that could be of interest to you:
fashing
(fashing)
September 11, 2023, 2:54am
3
Hi Mathieu,
Thank you for your information!
However, I got the following errors when I enabled the 2D Transfer Function checkbox.
I am using testcases from openvdb official website .
fashing
(fashing)
September 11, 2023, 7:44am
5
I encounter this error on all .vdb I found (e.g. torus )
And here’s the testcase I used for testing multi-color.
columns.vdb (1.2 MB)
mwestphal
September 11, 2023, 8:38am
6
The problem is that the data is read as a partitioned dataset with partial data on it. It would be better if the data was defined on all blocks.
fashing
(fashing)
September 11, 2023, 8:58am
7
I am not sure is this what you mean. (a grid contains all the data)
column.vdb (1.1 MB)
Though I still got the same error while enabling the 2D Transfer Function checkbox.
mwestphal
September 11, 2023, 9:01am
8
Indeed, looks like partitioned data is not well supported. You can work around it by using ResampleToImage filter.
Please open an issue though.
FYI @cory.quammen
