Is it possible to launch paraview automatically in Client/DataServer/RenderServer config?
I would like to automate the process of launching paraview in a context of a Client/data Server/Render Server. By hand I need to:
ssh -Y -L 11111:localhost:11111 server pvdataserver
on localhost: pvrendererserver
on localhost paraview
In the GUI, I then select connect and use or create the Client/DataServer/RenderServer config.
Thanks for any hints
Best
C.
Hi @Trophime ,
You can use the SSHCommand support using a .pvsc file:
https://docs.paraview.org/en/latest/ReferenceManual/parallelDataVisualization.html#case-sixteen-secured-connection-to-a-server-trough-ssh-tunnel
Best,
I am curious why do you use pvdataserver/renderserver mode if you’re running with pvrenderserver locally. Instead, pvserver+paraview would be a better config. Note, from settings you can disable remote rendering entirely by setting Remote Rendering Threshold to max. Then all rendering will happen locally.
