Sounds like an overflow issue. However, iso-volume may not be the most memory (or computation) efficient here since it will generate an unstructured grid for the full extracted volume. If you’re just interested in the low-iso-value high-iso-value surfaces, contour filter may be the better option.
Another option is to run with a parallel pvserver, so that the data gets splits into multiple chucks and thus avoid the overflow.
I am going to try to see if I can determine where the overflow is happening locally.
while I am sure it’s overflow, I am not sure where it’s happening. Ideally a debug build in a debugger would help, but let’s try one more thing. Is it possible to try out with the latest 5.7-RC? 5.7 supports a -l=<filename> argument that will make it save a log file. Try runnning paraview as follows:
> paraview -l=<filename>,TRACE
this will trace all filter executions and hopefully narrow down the location of the exception.
sweet, that helped! I see several vtkIdType to int conversions in vtkTableBasedClipDataSet::ClipRectilinearGridData which are causing the overflow. I’ll take a pass at cleaning it up for the next RC.
