I am getting error like double free or corruption (fasttop) when I try to render a very simple image with ParaView Catalyst. The trace looks like following (sorry I did not compile paraview or catalyst in debug mode yet to see the actual lines but if it is required I could work on it. The same code is working with gridwriter.py script provided by ParaView Catalyst without any issue. I also tried with replacing catalyst_conduit_node_set_path_external_* calls with the catalyst_conduit_node_set_path_* once in case of issue about sharing pointers between simulation code and catalyst but still getting same error. I wonder if I am missing something in here.
For your reference, I am building ParaView using super build with following options,
cmake -DPARAVIEW_EXTRA_CMAKE_ARGUMENTS="-DVTK_OPENGL_HAS_OSMESA=ON;-DVTK_USE_X=OFF;-DVTK_DEFAULT_RENDER_WINDOW_HEADLESS=ON;-DPARAVIEW_USE_QT=OFF" -DUSE_SYSTEM_catalyst=ON -DUSE_SYSTEM_zlib=ON -DUSE_SYSTEM_python3=ON -DUSE_SYSTEM_mpi=ON -DENABLE_osmesa=ON -DENABLE_mesa=OFF -DENABLE_catalyst=ON -DENABLE_fortran=ON -DENABLE_mpi=ON -DENABLE_python3=ON -DCMAKE_INSTALL_PREFIX:PATH=$PWD/install -DCMAKE_CXX_COMPILER=/glade/u/apps/common/23.08/spack/opt/spack/intel-oneapi-compilers/2023.2.1/compiler/2023.2.1/linux/bin/icpx -DCMAKE_C_COMPILER=/glade/u/apps/common/23.08/spack/opt/spack/intel-oneapi-compilers/2023.2.1/compiler/2023.2.1/linux/bin/icx -DCMAKE_MODULE_LINKER_FLAGS="-lstdc++exp" ../
libpthread-2.31.s 000014EB8E08D8C0 Unknown Unknown Unknown
libc-2.31.so 000014EB8DCCCCBB gsignal Unknown Unknown
libc-2.31.so 000014EB8DCCE355 abort Unknown Unknown
libc-2.31.so 000014EB8DD12AE7 Unknown Unknown Unknown
libc-2.31.so 000014EB8DD1AB6A Unknown Unknown Unknown
libc-2.31.so 000014EB8DD1C744 Unknown Unknown Unknown
libOSMesa.so.8 000014EB5F63E33A Unknown Unknown Unknown
libOSMesa.so.8 000014EB5F57EC6E Unknown Unknown Unknown
libOSMesa.so.8 000014EB5F5C6CEA Unknown Unknown Unknown
libOSMesa.so.8 000014EB5F59A841 Unknown Unknown Unknown
libOSMesa.so.8 000014EB5F1DF80C Unknown Unknown Unknown
libOSMesa.so.8 000014EB5F1BF8AC Unknown Unknown Unknown
libvtkRenderingOp 000014EB4B1570E3 _ZN16vtkShaderPro Unknown Unknown
libvtkRenderingOp 000014EB4B15851C _ZN16vtkShaderPro Unknown Unknown
libvtkRenderingOp 000014EB4B0ED4AF _ZN20vtkOpenGLSha Unknown Unknown
libvtkRenderingOp 000014EB4B0ECC22 _ZN20vtkOpenGLSha Unknown Unknown
libvtkRenderingOp 000014EB4B0C3616 _ZN23vtkOpenGLPol Unknown Unknown
libvtkRenderingOp 000014EB4B049DEF _ZN30vtkOpenGLBat Unknown Unknown
libvtkRenderingOp 000014EB4B047E92 _ZN30vtkOpenGLBat Unknown Unknown
libvtkRenderingOp 000014EB4B047C6D _ZN30vtkOpenGLBat Unknown Unknown
libvtkRenderingOp 000014EB4B047928 _ZN30vtkOpenGLBat Unknown Unknown
libvtkRenderingCo 000014EB488F03DA _ZN26vtkComposite Unknown Unknown
libvtkRenderingOp 000014EB4B045631 _ZN14vtkOpenGLAct Unknown Unknown
libvtkRemotingVie 000014EB5CB12076 _ZN13vtkPVLODActo Unknown Unknown
libvtkRemotingVie 000014EB5CB1217F _ZN13vtkPVLODActo Unknown Unknown
libvtkRenderingCo 000014EB489764B7 _ZN11vtkRenderer2 Unknown Unknown
libvtkRenderingOp 000014EB4B0E6320 _ZN17vtkOpenGLRen Unknown Unknown
libvtkRemotingVie 000014EB5CC0A58A _ZN20vtkIceTCompo Unknown Unknown
libvtkRemotingVie 000014EB5CC09C32 Unknown Unknown Unknown
libvtkIceTCore-pv 000014EB5ED1E7D4 Unknown Unknown Unknown
libvtkIceTCore-pv 000014EB5ED1EBB9 icetGetCompressed Unknown Unknown
libvtkIceTCore-pv 000014EB5ED2B2ED icetSequentialCom Unknown Unknown
libvtkIceTCore-pv 000014EB5ED18310 Unknown Unknown Unknown
libvtkRemotingVie 000014EB5CC09187 _ZN20vtkIceTCompo Unknown Unknown
libvtkRenderingOp 000014EB4B002054 _ZN13vtkCameraPas Unknown Unknown
libvtkRenderingOp 000014EB4B0E5A2E _ZN17vtkOpenGLRen Unknown Unknown
libvtkRenderingCo 000014EB489753EB _ZN11vtkRenderer6 Unknown Unknown
libvtkRenderingCo 000014EB4897D10F _ZN21vtkRendererC Unknown Unknown
libvtkRenderingCo 000014EB4896C9F1 _ZN15vtkRenderWin Unknown Unknown
libvtkRenderingCo 000014EB4896C7D2 _ZN15vtkRenderWin Unknown Unknown
libvtkRenderingOp 000014EB4B0E4047 _ZN21vtkOpenGLRen Unknown Unknown
libvtkRenderingOp 000014EB4B0270F8 _ZN28vtkGenericOp Unknown Unknown
libvtkRemotingVie 000014EB5CB4D577 Unknown Unknown Unknown
libvtkRemotingVie 000014EB5CB31213 _ZN15vtkPVRenderV Unknown Unknown
libvtkRemotingVie 000014EB5CB30534 _ZN15vtkPVRenderV Unknown Unknown
libvtkRemotingApp 000014EB65360CCE _Z22vtkPVRenderVi Unknown Unknown
libvtkRemotingCli 000014EB6ADEB076 _ZN26vtkClientSer Unknown Unknown
libvtkRemotingCli 000014EB6ADE9BA9 _ZN26vtkClientSer Unknown Unknown
libvtkRemotingCli 000014EB6ADE92D6 _ZN26vtkClientSer Unknown Unknown
libvtkRemotingCli 000014EB6ADE919D _ZN26vtkClientSer Unknown Unknown
libvtkRemotingSer 000014EB6BE3A3F5 _ZN16vtkPVSession Unknown Unknown
libvtkRemotingSer 000014EB6BE3A133 _ZN16vtkPVSession Unknown Unknown
libvtkRemotingSer 000014EB6BE3764F _ZN16vtkPVSession Unknown Unknown
libvtkRemotingVie 000014EB5CBE65C1 _ZN14vtkSMViewPro Unknown Unknown
libvtkRemotingVie 000014EB5CBAD431 _ZN20vtkSMRenderV Unknown Unknown
libvtkRemotingVie 000014EB5CBE72B0 _ZN14vtkSMViewPro Unknown Unknown
libvtkRemotingVie 000014EB5CBE7121 _ZN14vtkSMViewPro Unknown Unknown
libvtkRemotingVie 000014EB5CBE8C60 Unknown Unknown Unknown
libvtkRemotingVie 000014EB5CBE82D0 Unknown Unknown Unknown
libvtkRemotingVie 000014EB5CBE702D _ZN14vtkSMViewPro Unknown Unknown
libvtkRemotingVie 000014EB5CBB7EFA Unknown Unknown Unknown
libvtkRemotingVie 000014EB5CBB65F3 Unknown Unknown Unknown
libvtkRemotingVie 000014EB5CBB2C2C _ZN24vtkSMSaveScr Unknown Unknown
libvtkRemotingVie 000014EB5CB97325 _ZN28vtkSMImageEx Unknown Unknown
libvtkRemotingVie 000014EB5CB963CB _ZN28vtkSMImageEx Unknown Unknown
libvtkRemotingVie 000014EB5CB95FA9 _ZN28vtkSMImageEx Unknown Unknown
libvtkRemotingSer 000014EB6BE9A394 _ZN23vtkSMExtract Unknown Unknown
libvtkRemotingSer 000014EB6BE9A5DE _ZN23vtkSMExtract Unknown Unknown
libvtkPVPythonCat 000014EB664B18CD _ZN25vtkCPPythonS Unknown Unknown
libvtkPVInSitu-pv 000014EB6C52CE31 _ZN29vtkInSituIni Unknown Unknown
libvtkPVInSitu-pv 000014EB6C52C6C3 _ZN29vtkInSituIni Unknown Unknown
libcatalyst-parav 000014EB6C748908 Unknown Unknown Unknown
