hello,
I am running the following lines of code:
if sliceFilter==[]:
sliceFilter= GetActiveSource()
originOfSlice=sliceFilter.SliceType.Origin
sliceFilterMerged=MergeBlocks(registrationName='MergeBlocks1', Input=sliceFilter)
transform1 = Transform(registrationName='Transform1', Input=sliceFilterMerged)
transform1.Transform.Translate = [-i for i in originOfSlice]
anglesToRotate = angles_to_align_with_z(normalOfSlice)
transform2 = Transform(registrationName='Transform1', Input=transform1)
transform2.Transform.Rotate = anglesToRotate
extractSurface1 = ExtractSurface(registrationName='ExtractSurface1', Input=transform2)
surfaceNormals = SurfaceNormals(registrationName='SurfaceNormals1', Input=extractSurface1)
filterForFlags = Threshold(registrationName='Threshold1', Input=surfaceNormals)
filterForFlags.Scalars = ['POINTS', 'Normals']
filterForFlags.SelectedComponent = 'Z'
filterForFlags.LowerThreshold = -100000000000000
filterForFlags.UpperThreshold = 0
but I having the following error: when running it:
File "/home/franco/Programs/ParaView/ParaView-6.0.1-MPI-Linux-Python3.12-x86_64/lib/python3.12/site-packages/paraview/servermanager.py", line 519, in __setattr__
setter(self, value)
File "/home/franco/Programs/ParaView/ParaView-6.0.1-MPI-Linux-Python3.12-x86_64/lib/python3.12/site-packages/paraview/servermanager.py", line 2979, in setProperty
return self.SetPropertyWithName(propName, value)
File "/home/franco/Programs/ParaView/ParaView-6.0.1-MPI-Linux-Python3.12-x86_64/lib/python3.12/site-packages/paraview/servermanager.py", line 361, in SetPropertyWithName
prop.SetData(arg)
File "/home/franco/Programs/ParaView/ParaView-6.0.1-MPI-Linux-Python3.12-x86_64/lib/python3.12/site-packages/paraview/servermanager.py", line 1176, in SetData
convertedValues = list(map(self.ConvertValue, values))
File "/home/franco/Programs/ParaView/ParaView-6.0.1-MPI-Linux-Python3.12-x86_64/lib/python3.12/site-packages/paraview/servermanager.py", line 1296, in ConvertValue
raise ValueError("%s is not a valid value." % value)
ValueError: Z is not a valid value.
During handling of the above exception, another exception occurred:
File "/home/franco/Programs/ParaView/ParaView-6.0.1-MPI-Linux-Python3.12-x86_64/lib/python3.12/site-packages/paraview/servermanager.py", line 523, in __setattr__
setter(self, _make_name_valid(value))
prop.SetData(arg)
File "/home/franco/Programs/ParaView/ParaView-6.0.1-MPI-Linux-Python3.12-x86_64/lib/python3.12/site-packages/paraview/servermanager.py", line 527, in __setattr__
_bc.setattr_fix_value(self, name, value, setter)
File "/home/franco/Programs/ParaView/ParaView-6.0.1-MPI-Linux-Python3.12-x86_64/lib/python3.12/site-packages/paraview/_backwardscompatibilityhelper.py", line 680, in setattr_fix_value
raise ValueError("'%s' is not a valid value for %s!" % (value, pname))
ValueError: 'Z' is not a valid value for SelectedComponent!
File "<console>", line 1, in <module>
File "<console>", line 20, in exportSvgOfSlice
File "/home/franco/Programs/ParaView/ParaView-6.0.1-MPI-Linux-Python3.12-x86_64/lib/python3.12/site-packages/paraview/servermanager.py", line 531, in __setattr__
raise ValueError("%s is not a valid value for attribute %s." % (value, name))
ValueError: Z is not a valid value for attribute SelectedComponent.
As it can be seen in the message error, it does not find the Z component, but while runned, this will create the corresponding filters on the pipeline browser, if once runned (and the filters created) i hit on the eye to show the surfaceNormals filter, and then hit the eye on the threshold, i can select points/Normals and Z component without issues.
not sure what i am missing.
