Hello, I got following issues when compiling the v5.8.0 on nersc cori cluster:
$ cmake ~/cworkspace/src/ParaView/ -DPARAVIEW_USE_QT=OFF -DPARAVIEW_USE_PYTHON=ON -DPARAVIEW_USE_MPI=ON -DVTK_OPENGL_HAS_OSMESA:BOOL=TRUE -DVTK_USE_X:BOOL=FALSE -DCMAKE_CXX_COMPILER=CC -DCMAKE_C_COMPILER=cc -DMPI_C_COMPILER=cc -DMPI_CXX_COMPILER=CC
-- The C compiler identification is GNU 8.3.0
-- The CXX compiler identification is GNU 8.3.0
-- Cray Programming Environment 2.6.2 C
-- Check for working C compiler: /opt/cray/pe/craype/2.6.2/bin/cc
-- Check for working C compiler: /opt/cray/pe/craype/2.6.2/bin/cc -- broken
CMake Error at /global/common/sw/cray/cnl7/haswell/cmake/3.14.4/gcc/8.2.0/2hef55n/share/cmake-3.14/Modules/CMakeTestCCompiler.cmake:60 (message):
The C compiler
"/opt/cray/pe/craype/2.6.2/bin/cc"
is not able to compile a simple test program.
It fails with the following output:
Change Dir: /global/cscratch1/sd/zw241/build_paraview_v580/CMakeFiles/CMakeTmp
Run Build Command(s):/usr/bin/gmake cmTC_4d32f/fast
/usr/bin/gmake -f CMakeFiles/cmTC_4d32f.dir/build.make CMakeFiles/cmTC_4d32f.dir/build
gmake[1]: Entering directory '/global/cscratch1/sd/zw241/build_paraview_v580/CMakeFiles/CMakeTmp'
Building C object CMakeFiles/cmTC_4d32f.dir/testCCompiler.c.o
/opt/cray/pe/craype/2.6.2/bin/cc -o CMakeFiles/cmTC_4d32f.dir/testCCompiler.c.o -c /global/cscratch1/sd/zw241/build_paraview_v580/CMakeFiles/CMakeTmp/testCCompiler.c
Linking C executable cmTC_4d32f
/global/common/sw/cray/cnl7/haswell/cmake/3.14.4/gcc/8.2.0/2hef55n/bin/cmake -E cmake_link_script CMakeFiles/cmTC_4d32f.dir/link.txt --verbose=1
/opt/cray/pe/craype/2.6.2/bin/cc CMakeFiles/cmTC_4d32f.dir/testCCompiler.c.o -o cmTC_4d32f
/opt/gcc/8.3.0/snos/lib/gcc/x86_64-suse-linux/8.3.0/crtbegin.o: in function `deregister_tm_clones':
crtstuff.c:(.text+0x7): relocation truncated to fit: R_X86_64_32S against `.tm_clone_table'
/opt/gcc/8.3.0/snos/lib/gcc/x86_64-suse-linux/8.3.0/crtbegin.o: in function `register_tm_clones':
crtstuff.c:(.text+0x38): relocation truncated to fit: R_X86_64_32S against `.tm_clone_table'
collect2: error: ld returned 1 exit status
gmake[1]: *** [CMakeFiles/cmTC_4d32f.dir/build.make:87: cmTC_4d32f] Error 1
gmake[1]: Leaving directory '/global/cscratch1/sd/zw241/build_paraview_v580/CMakeFiles/CMakeTmp'
gmake: *** [Makefile:121: cmTC_4d32f/fast] Error 2
CMake will not be able to correctly generate this project.
CMakeLists.txt:32 (project)
-- Configuring incomplete, errors occurred!
See also "/global/cscratch1/sd/zw241/build_paraview_v580/CMakeFiles/CMakeOutput.log".
See also "/global/cscratch1/sd/zw241/build_paraview_v580/CMakeFiles/CMakeError.log".
But it is ok to compile when I use following commands:
I am not sure the reason behind this, but it seems that the cmake failed after I load the mesa by spack, for this example, it runs well at the first time and then I load the mesa and delete the CMakeCache, then it failed to compile the paraview
-- Check for working C compiler: /opt/cray/pe/craype/2.6.2/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Cray Programming Environment 2.6.2 CXX
-- Check for working CXX compiler: /opt/cray/pe/craype/2.6.2/bin/CC
-- Check for working CXX compiler: /opt/cray/pe/craype/2.6.2/bin/CC -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Setting build type to 'Debug' as none was specified.
-- Performing Test HAVE_GCC_ERROR_RETURN_TYPE
-- Performing Test HAVE_GCC_ERROR_RETURN_TYPE - Success
-- Performing Test Support for 64 bit file systems
-- Performing Test Support for 64 bit file systems - Success
-- Looking for a Fortran compiler
^C
zw241@cori01:/global/cscratch1/sd/zw241/build_paraview_v580$ ls
CMakeCache.txt ExternalData VTKExtensions cmake_install.cmake paraview-config.cmake vtk-config.cmake
CMakeFiles Makefile Web lib64 paraview-modules.json vtk-modules.json
CTestTestfile.cmake Testing Wrapping package.json requirements.txt
DartConfiguration.tcl VTK bin paraview-config-version.cmake vtk-config-version.cmake
zw241@cori01:/global/cscratch1/sd/zw241/build_paraview_v580$ rm CMakeCache.txt
zw241@cori01:/global/cscratch1/sd/zw241/build_paraview_v580$ spack load mesa/qozjngg
zw241@cori01:/global/cscratch1/sd/zw241/build_paraview_v580$ cmake ~/cworkspace/src/ParaView/ -DPARAVIEW_USE_QT=OFF -DPARAVIEW_USE_PYTHON=ON -DPARAVIEW_USE_MPI=ON -DVTK_OPENGL_HAS_OSMESA:BOOL=TRUE -DVTK_USE_X:BOOL=FALSE -DCMAKE_CXX_COMPILER=CC -DCMAKE_C_COMPILER=cc -DMPI_C_COMPILER=cc -DMPI_CXX_COMPILER=CC
The C compiler
Run Build Command(s):/usr/bin/gmake cmTC_2d981/fast
/usr/bin/gmake -f CMakeFiles/cmTC_2d981.dir/build.make CMakeFiles/cmTC_2d981.dir/build
