Issues Using Server GPU for Rendering with ParaView
I am experiencing issues when attempting to use the server’s GPU for rendering while utilizing ParaView’s server functionality.
1. Goal:
I am trying to use the server-side data and leverage the server’s GPU for rendering.
2. Issue Summary:
While rendering data on the local machine using server-side data works without any problems, I encounter errors when trying to use the server’s GPU for rendering.
3. Current Setup:
Upon connecting to the server, the nvidia-smi command shows that the task is recognized by the GPU, as shown below:
| NVIDIA-SMI 525.60.13    Driver Version: 525.60.13    CUDA Version: 12.0     |
| GPU  Name        Persistence-M| Bus-Id        Disp.A | Volatile Uncorr. ECC |
| Fan  Temp  Perf  Pwr:Usage/Cap|         Memory-Usage | GPU-Util  Compute M. |
|                               |                      |               MIG M. |
|   0  NVIDIA GeForce ...  On   | 00000000:01:00.0 Off |                  N/A |
| 36%   35C    P8    13W / 180W |      4MiB /  8192MiB |      0%      Default |
|                               |                      |                  N/A |
|   1  NVIDIA GeForce ...  On   | 00000000:02:00.0 Off |                  N/A |
| 36%   34C    P8     8W / 180W |      2MiB /  8192MiB |      0%      Default |
|                               |                      |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                  GPU Memory |
|        ID   ID                                                   Usage      |
|    0   N/A  N/A      4023      G   ...-x86_64/bin/pvserver-real        1MiB |
4. Problem Description:
I can load the file and see it in the Pipeline Browser. However, as soon as I attempt to apply properties or make the object visible, ParaView crashes on the local machine, and errors appear on the Linux server.
Here is the process I followed for the Data Server:
$ pvserver --server-port=11111
Waiting for client...
Connection URL: cs://user:11111
Accepting connection(s): user:11111
Client connected.
ConnectMtoN
  By loading the 'pvNVIDIAIndeX' plugin you have accepted the EULA shipped with it.
  If that is not acceptable, please restart the application without loading
  the 'pvNVIDIAIndeX' plugin.
( 377.070s) [pvserver        ]vtkSocketCommunicator.c:774    ERR| vtkSocketCommunicator (0x1a61310): Could not receive tag. 41235
( 377.070s) [pvserver        ]vtkSocketCommunicator.c:774    ERR| vtkSocketCommunicator (0x1a61310): Could not receive tag. 41233
( 377.070s) [pvserver        ]vtkSocketCommunicator.c:774    ERR| vtkSocketCommunicator (0x1a61310): Could not receive tag. 1
( 377.071s) [pvserver        ]vtkTCPNetworkAccessMana:284    ERR| vtkTCPNetworkAccessManager (0x19720e0): Some error in socket processing.
And for the Rendering Server:
$ pvserver --server-port=11112
Connection URL: cs://user:11112
Accepting connection(s): user:11112
Client connected.
ConnectMtoN
( 362.189s) [pvserver        ]vtkSocketCommunicator.c:839    ERR| vtkSocketCommunicator (0x903250): Tag mismatch: got 102290, expecting 41235.
( 362.202s) [pvserver        ]vtkSocketCommunicator.c:839    ERR| vtkSocketCommunicator (0x903250): Tag mismatch: got 102290, expecting 41233.
( 366.086s) [pvserver        ]vtkSocketCommunicator.c:774    ERR| vtkSocketCommunicator (0x903250): Could not receive tag. 1
( 366.087s) [pvserver        ]vtkTCPNetworkAccessMana:284    ERR| vtkTCPNetworkAccessManager (0x8140e0): Some error in socket processing.
5. Cross-Platform Issue:
I have tried this process on two different local machines (macOS and Windows 11), and the issue persists across both platforms.
6. Environment Details:
• ParaView Version: 5.13.1 (MPI version) on both Linux server and local machines.
• Server Installation: The Linux server uses the EGL version of ParaView.
Could you please assist in identifying the cause of these errors and provide guidance on how to resolve this issue?
Thank you.
Looks like you are loading the Index plugin, is that intended ?
Thanks.
Yes. I want to fully utilize my gpu therefore i tried to use NVIDIAIndeX.
I followed the 3.4 NVIDIAIndeXsettings of the NVIDIA IndeX ParaView Plugin User’s Guide. Is it correct approach to achieve my goal?
I have to render quite heavy files ( ~3GiB vtk file per timestep) therefore using server GPU and ram. It will be thankfull if you give any advice.
Well, this only makes sense if you want to do volume rendering.
In any case I tried using NVidia index with EGL pvserver and it worked fine.
Which version of libegl are you using on the server side ? Which OS are you using ?
Thanks for additional support.
Before answering, i should inform you that problem has little bit solved with using
pvrenderserver and pvdataserver instead pvserver twice.(with port 11111 and 22221)
Now I can render my files in linux server with “client/data server/render server”, but following error occurs, therefore I can utilize my GPU.
Anyhow,
libegl version
root@user:~# dpkg -l | grep libegl
ii  libegl-mesa0:amd64                         20.0.8-0ubuntu1~18.04.1                         amd64        free implementation of the EGL API -- Mesa vendor library
ii  libegl-mesa0:i386                          20.0.8-0ubuntu1~18.04.1                         i386         free implementation of the EGL API -- Mesa vendor library
ii  libegl1:amd64                              1.0.0-2ubuntu2.3                                amd64        Vendor neutral GL dispatch library -- EGL support
ii  libegl1:i386                               1.0.0-2ubuntu2.3                                i386         Vendor neutral GL dispatch library -- EGL support
ii  libegl1-mesa:amd64                         20.0.8-0ubuntu1~18.04.1                         amd64        transitional dummy package
OS
root@user:~# lsb_release -a
No LSB modules are available.
Distributor ID: Ubuntu
Description:    Ubuntu 18.04.6 LTS
Release:        18.04
Codename:       bionic
Remote Rendering will be disabled
You are not using your server GPU at all in that case.
Ubuntu 18.04.6 LTS
This version of libegl is non fonctionnal, you need to update to Ubuntu 20 at least.
So you mean there is no other way to use gpu with ubuntu 18?
Sorry but for me it’s weird that It works well with other Ubuntu18 server.
This is settings of my secondary server.
(base) root@user:~# dpkg -l | grep libegl
(base) root@user:~# lsb_release -a
Release:        18.04
Codename:       bionic
For example, in the same way with client/dataserver/renderserver, It seems that it utilize GPU well.
(base) root@user:~# nvidia-smi
Wed Oct 23 23:31:02 2024
| NVIDIA-SMI 530.30.02              Driver Version: 530.30.02    CUDA Version: 12.1     |
|                                         |                      |               MIG M. |
|   0  NVIDIA GeForce RTX 3090         On | 00000000:B4:00.0 Off |                  N/A |
| 49%   48C    P2              188W / 350W|    510MiB / 24576MiB |    100%      Default |
|                                         |                      |                  N/A |
|   1  NVIDIA GeForce RTX 3090         On | 00000000:B6:00.0 Off |                  N/A |
| 30%   25C    P8               18W / 350W|    115MiB / 24576MiB |      0%      Default |
|                                         |                      |                  N/A |
|   2  NVIDIA GeForce RTX 3090         On | 00000000:BB:00.0 Off |                  N/A |
| 30%   25C    P8               19W / 350W|      3MiB / 24576MiB |      0%      Default |
|                                         |                      |                  N/A |
|   3  NVIDIA GeForce RTX 3090         On | 00000000:BC:00.0 Off |                  N/A |
| 30%   25C    P8               23W / 350W|      3MiB / 24576MiB |      0%      Default |
|                                         |                      |                  N/A |
|   4  NVIDIA GeForce RTX 3090         On | 00000000:BE:00.0 Off |                  N/A |
| 48%   24C    P8               17W / 350W|      3MiB / 24576MiB |      0%      Default |
|                                         |                      |                  N/A |
|   5  NVIDIA GeForce RTX 3090         On | 00000000:C4:00.0 Off |                  N/A |
| 44%   52C    P2              216W / 350W|    503MiB / 24576MiB |    100%      Default |
|                                         |                      |                  N/A |
|   6  NVIDIA GeForce RTX 3090         On | 00000000:C6:00.0 Off |                  N/A |
| 30%   25C    P8               15W / 350W|      3MiB / 24576MiB |      0%      Default |
|                                         |                      |                  N/A |
|   7  NVIDIA GeForce RTX 3090         On | 00000000:CC:00.0 Off |                  N/A |
| 30%   25C    P8               21W / 350W|      3MiB / 24576MiB |      0%      Default |
|                                         |                      |                  N/A |
|   8  NVIDIA GeForce RTX 3090         On | 00000000:CD:00.0 Off |                  N/A |
| 50%   24C    P8               18W / 350W|      3MiB / 24576MiB |      0%      Default |
|                                         |                      |                  N/A |
| Processes:        |
|        ID   ID                                                             Usage      |
|    0   N/A  N/A     17740      C   ./CFD_gpu                                502MiB |
|    0   N/A  N/A     18293      G   ...3.10-x86_64/bin/pvrenderserver-real        4MiB |
|    1   N/A  N/A     18293      G   ...3.10-x86_64/bin/pvrenderserver-real      111MiB |
|    5   N/A  N/A     17700      C   ./CFD_gpu                                500MiB |
with pvrenderserver --display=1.
If there anything I should know about linux openGL settings or something else, please let me know. Sorry that I am not very familiar with Linux :blush: …
Thank you.
To make sure:
Edit → Serttings → RenderView → Check ShowAnnotation
Remote Rendering should be true in the annotation.
Thanks!
Now i’m sure that it works with remote server.
Sorry but is there any other potential Issue that makes something wrong with my preliminary server??.
Im afraid I do not know.
The error message indicates VMware vendoring. Are you using a virtual machine to run pvserver? If yes, I would check that your VM have access to the graphic drivers.
Thanks.
I’m afraid that it isn’t.
root@user:~# sudo dmidecode | grep -i vmware
root@user:~# lscpu | grep -i hypervisor
root@user:~# dmesg | grep -i vmware
root@user:~# ls /sys/class/dmi/id/product_name
