When attempting to create slices from exodus files using TETRA14 elements, all we see is the outline of the slice, e.g. it’s as if the parent mesh is a surface mesh instead of a volumetric one. There is no problem with TETRA4 or TETRA10 elements. The attached exodus file demonstrates the issue which we’ve tested in ParaView 5.12 and 5.13.3.
VTK does not currently support a 14-node tetrahedron (though the IOSS library does). VTK supports a 15-node tetrahedron. Presumably the difference is a body-centered node.
Also, I see larger issues when loading the data you attached into ParaView 6.x:
VTK’s IOSS-based reader does not create any cells at all from the file.
loading the plugin for the legacy Exodus-based reader creates cells but appears to mistreat the connectivity data (see image).
