I’m attempting to launch a pvserver and connect to it on a Windows machine, following the guide here: ParaView:Server Configuration - KitwarePublic. Unfortunately, the process fails with the following error:
critical: In unknown, line 0
critical: The process failed to start. Either the invoked program is missing, or you may have insufficient permissions to invoke the program.
critical: Command launch timed out.
Does anyone have experience getting this to work on Windows? Running Paraview as Administrator doesn’t seem to help, and would be a problem anyway.
If it is still actual, you can add ‘C:\Program Files\ParaView 5.9.1-MPI-Windows-Python3.8-msvc2017-64bit\bin’ to path variable on your Windows machine, restart ParaView client, and then use the following .pvsc file:
<Servers>
<Server name="case6_modified" resource="cs://localhost">
<CommandStartup>
<Options>
<!-- The user chooses the port on which to start the server -->
<Option name="PV_SERVER_PORT" label="Server Port: ">
<Range type="int" min="1" max="65535" step="1" default="11111" />
</Option>
</Options>
<Command exec="pvserver -sp=$PV_SERVER_PORT$" delay="5">
</Command>
</CommandStartup>
</Server>
</Servers>
