Lib issue - Conda - Ipyhton - 2,7
Hi everyone,
I have installed Paraview using a conda environment, where I installed Python 2.7.10, which is the only compatible version with Paraview, as far as I know. The installation went well and now I have Paraview installed in my conda environment. However, when I tried to run:
**ParaView.simple import ***
I get the following message:
ImportError: dlopen(//anaconda3/envs/py2_7/lib/python2.7/site-packages/vtkmodules/vtkParallelCorePython.so, 2): Library not loaded: @rpath/libdouble-conversion.3.dylib
** Referenced from: //anaconda3/envs/py2_7/lib/libvtkIOCore-pv5.7.1.dylib**
Has anyone experienced something similar or have any approach to solve this error?
Thank you in advance for your support.
Cheers,
** Reason: image not found**
It is likely how paraview was built by the conda recipe. I suggest to create an issue / ask the conda recipe maintainers.
Dan
I fixed the issue, I needed the update Paraview from the conda env with Python 2.7.10 and now it’s working well.
In a different note: Do you mind telling how to use the * paraview.simple. EnSightReader ( *input , *params ) ?
I have my .case file but I was not able to read it in Python.
Thank you,
Alfonso, you should as ask this question in a different topic with the right descriptive title so that people know it was not answered.
Thanks,
Dan
Hi Dean,
Thank you, will do.
Cheers,
