libEGL warning, unsure if I am using the server GPU
I have access to a remote box running Ubuntu 22 with an RTX A5000
I started pvserver (5.13.1) on the box and connected to it but I get the following
I am connecting from a Windows box running Paraview 5.13.1
What steps should I take to address to warnings ?
Client connected.
libEGL warning: egl: failed to create dri2 screen
(  19.567s) [pvserver        ] vtkEGLRenderWindow.cxx:340   WARN| vtkEGLRenderWindow (0x5d54450): EGL device index: 0 could not be initialized. Trying other devices...
The driver information on the remote GPU machine is as such
| NVIDIA-SMI 550.127.08             Driver Version: 550.127.08     CUDA Version: 12.4     |
| GPU  Name                 Persistence-M | Bus-Id          Disp.A | Volatile Uncorr. ECC |
| Fan  Temp   Perf          Pwr:Usage/Cap |           Memory-Usage | GPU-Util  Compute M. |
|                                         |                        |               MIG M. |
|   0  NVIDIA RTX A5000               Off |   00000000:00:10.0 Off |                  Off |
| 30%   31C    P0             73W /  230W |       1MiB /  24564MiB |      0%      Default |
|                                         |                        |                  N/A |
| Processes:        |
|  GPU   GI   CI        PID   Type   Process name                              GPU Memory |
|        ID   ID                                                               Usage      |
|  No running processes found                                                             |
