In version 4.xx of LidarView I was able to use the SLAM filter, and by simply pressing the play button I could see the trajectory being created and the full cloud being created. I have just tried V5 and 5.0.1 and when I add the SLAM filter and press play it just shows single frames of the data and no trajectory being made. Edge map, intensity map etc are all empty too. It looks like SLAM is not working. It’s the same Hesai XT32 pcap, same default basic settings. Any idea what I am doing wrong?
Hi @enxcjbc,
Could you please share your pcap ? What is the exact version of LidarView 4.xx you were using ?
Thanks,
Timothée Couble
Hi Timothée,
The old version that it did work on was 4.5.1.
I have output the first 500 frames to a new pcap as the original is quite large. I have uploaded it here:
HesaiXT32.pcap
Thanks in advance for your help,
Chris
Thanks for answering so quickly, I can confirm that it works now.
Best regards,
Chris
