I’m using Paraview 5.7.0. When I do PlotOverLine on data from Nek5000 running Paraview in serial, it works fine. But when I run in parallel, the line probe fails. Basically, it doesn’t show the Nek5000 variables, only stuff like Points_X, Points_Y, etc. This also happened with versions 5.4 - 5.6. Is it a bug? Is there a workaround?
Thank you for your reply. The first option worked well for me. The second option caused Paraview to crash. I was running it as client-server mode, and this is the last few lines from the console where I was running pvserver:
( 468.216s) [pvserver.0 ]vtkPVDataInformation.cx:1446 ERR| vtkPVDataInformation (0x90eae70): Error parsing class name of data.
( 468.316s) [pvserver.0 ] vtkMPICommunicator.cxx:71 WARN| MPI had an error
Message truncated, error stack:
PMPI_Gatherv(416)...................: MPI_Gatherv failed(sbuf=0xae09040, scount=757, MPI_UNSIGNED_CHAR, rbuf=0xa721180, rcnts=0xa87bc30, displs=0xa87bed0, datatype=MPI_UNSIGNED_CHAR, root=0, comm=MPI_COMM_WORLD) failed
MPIR_Gatherv_impl(184)..............:
MPIR_Gatherv_intra_auto(93).........:
MPIR_Gatherv_allcomm_linear(99).....:
MPIC_Irecv(596).....................:
MPIDI_CH3U_Request_unpack_uebuf(516): Message truncated; 926 bytes received but buffer size is 757
application called MPI_Abort(MPI_COMM_WORLD, 808023310) - process 0
