It looks like lines depth is not calculated correctly in my ParaView desktop setup. I have attached an example image below from a CFD case. The image shows a wing with pressure contours on it and a slice in the flow field, normal to the wing. The slice shows pressure contours as well as the computational grid. As you can see, the grid depth is not calculated correctly and many cells are shown on top of the wing.
Any suggestions as to what might be causing this? Is this entirely a graphic card issue?
Paraview 5.7.0
Linux Ubuntu 18.04.4 LTS
Quadro P620, NVIDIA driver 430.50
