Loading PyFR .vtu files error using ParaView 5.13.3
Dear ParaView Support,
I was trying to open a .vtu file generated by PyFR using ParaView 5.13.3. And i get this error:
ERROR: In vtkXMLUnstructuredDataReader.cxx, line 766
vtkXMLUnstructuredGridReader (00000272CF3EA3D0): Cannot read cell connectivity from Cells in piece 2 because the “offsets” array is not monotonically increasing or starts with a value other than 0.
vtkXMLUnstructuredGridReader (00000272CE40D110): Cannot read cell connectivity from Cells in piece 2 because the “offsets” array is not monotonically increasing or starts with a value other than 0.
However, this is the same file which I used to be able to load using earlier version of ParaView in 2024.
Could please help me with the proper loading file steps? Or could you please check whether the file itself was damaged?
please find the file on the shared google drive, Thanks a lot and I look forward to your guidance!
Please share your data
I have approved your access request, please let me know if there’s issues viewing it. Thank you very much!
I reproduce the issue but I think the error is genuine, you need to fix your data.
ParaView 5.9 (2021) is unable to read this data and fails with the same error, so I doubt that.
