Hey all,
I’m running Paraview version 5.10.1 on Ubuntu and I’m trying to compile a Python script that crashes at the command line trying to compile paraview.simple.TableToPoints with:
Loguru caught a signal: SIGSEGV
Stack trace:
38 0x401f7f /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/pvpython-real() [0x401f7f]
37 0x7fe1e9cdee40 __libc_start_main + 128
36 0x7fe1e9cded90 /lib/x86_64-linux-gnu/libc.so.6(+0x29d90) [0x7fe1e9cded90]
35 0x4027be /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/pvpython-real() [0x4027be]
34 0x7fe1e6e08db4 vtkPythonInterpreter::PyMain(int, char**) + 532
33 0x7fe1e2e2e053 Py_Main + 67
32 0x7fe1e2e2dbf0 Py_RunMain + 1936
31 0x7fe1e2e09948 PyRun_SimpleFileExFlags + 376
30 0x7fe1e2e07a25 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x207a25) [0x7fe1e2e07a25]
29 0x7fe1e2dc331b PyEval_EvalCode + 27
28 0x7fe1e2dc32ee PyEval_EvalCodeEx + 62
27 0x7fe1e2dc32a2 _PyEval_EvalCodeWithName + 82
26 0x7fe1e2dc2f09 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x1c2f09) [0x7fe1e2dc2f09]
25 0x7fe1e2c6ddcb _PyEval_EvalFrameDefault + 22283
24 0x7fe1e2c67187 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x67187) [0x7fe1e2c67187]
23 0x7fe1e2c6dd2d _PyEval_EvalFrameDefault + 22125
22 0x7fe1e2cbd2d1 _PyFunction_Vectorcall + 177
21 0x7fe1e2dc2f09 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x1c2f09) [0x7fe1e2dc2f09]
20 0x7fe1e2c6e750 _PyEval_EvalFrameDefault + 24720
19 0x7fe1e2c682a7 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x682a7) [0x7fe1e2c682a7]
18 0x7fe1e2cc0be3 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0xc0be3) [0x7fe1e2cc0be3]
17 0x7fe1e2c67187 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x67187) [0x7fe1e2c67187]
16 0x7fe1e2c6e750 _PyEval_EvalFrameDefault + 24720
15 0x7fe1e2c682a7 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x682a7) [0x7fe1e2c682a7]
14 0x7fe1e2cc0be3 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0xc0be3) [0x7fe1e2cc0be3]
13 0x7fe1e2c67187 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x67187) [0x7fe1e2c67187]
12 0x7fe1e2c6e750 _PyEval_EvalFrameDefault + 24720
11 0x7fe1e2c6830b /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x6830b) [0x7fe1e2c6830b]
10 0x7fe1e2cbd4ee _PyObject_MakeTpCall + 158
9 0x7fe1e2d1850b /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x11850b) [0x7fe1e2d1850b]
8 0x7fe1954b15a1 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/lib/python3.9/site-packages/paraview/modules/vtkRemotingServerManager.so(+0xb15a1) [0x7fe1954b15a1]
7 0x7fe1e7d4a84b vtkSMInputProperty::AddInputConnection(vtkSMProxy*, unsigned int) + 427
6 0x7fe1e25b68f9 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libvtkCommonCore-pv5.10.so.1(+0x5b68f9) [0x7fe1e25b68f9]
5 0x7fe1e7d8ce2b vtkObject::vtkClassMemberCallback<vtkSMProperty>::operator()(vtkObject*, unsigned long, void*) + 59
4 0x7fe1e7d87323 vtkSMProperty::UpdateDomains() + 67
3 0x7fe1e7d08369 vtkSMArrayListDomain::Update(vtkSMProperty*) + 217
2 0x7fe1e7d0791d /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libvtkRemotingServerManager-pv5.10.so.1(+0x10791d) [0x7fe1e7d0791d]
1 0x7fe1e9e5297d /lib/x86_64-linux-gnu/libc.so.6(+0x19d97d) [0x7fe1e9e5297d]
0 0x7fe1e9cf7520 /lib/x86_64-linux-gnu/libc.so.6(+0x42520) [0x7fe1e9cf7520]
( 1.877s) [paraview ] :0 FATL| Signal: SIGSEGV
error: exception occurred: Segmentation fault
Process finished with exit code 1
In case I try to run the script directly from the Paraview GUI (mesa) I get
Stack trace:
59 0x40802a /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/paraview-real() [0x40802a]
58 0x7f466b2b5e40 __libc_start_main + 128
57 0x7f466b2b5d90 /lib/x86_64-linux-gnu/libc.so.6(+0x29d90) [0x7f466b2b5d90]
56 0x407c8a /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/paraview-real() [0x407c8a]
55 0x7f4667a84120 QCoreApplication::exec() + 128
54 0x7f4667a7b62a QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 298
53 0x7f460c25ee13 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/plugins/platforms/../../lib/libQt5XcbQpa.so.5(+0x5ee13) [0x7f460c25ee13]
52 0x7f46682ee0db QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 187
51 0x7f4668312b35 QGuiApplicationPrivate::processWindowSystemEvent(QWindowSystemInterfacePrivate::WindowSystemEvent*) + 261
50 0x7f46683118ad QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) + 1837
49 0x7f4667a7cdd8 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 280
48 0x7f466a363260 QApplication::notify(QObject*, QEvent*) + 704
47 0x7f466a35c18c QApplicationPrivate::notify_helper(QObject*, QEvent*) + 156
46 0x7f466a3b68fb /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libQt5Widgets.so.5(+0x1b68fb) [0x7f466a3b68fb]
45 0x7f466a3b3d86 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libQt5Widgets.so.5(+0x1b3d86) [0x7f466a3b3d86]
44 0x7f466a3627cc QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool, bool) + 460
43 0x7f4667a7cdd8 QCoreApplication::notifyInternal2(QObject*, QEvent*) + 280
42 0x7f466a363dc8 QApplication::notify(QObject*, QEvent*) + 3624
41 0x7f466a35c18c QApplicationPrivate::notify_helper(QObject*, QEvent*) + 156
40 0x7f466a399c28 QWidget::event(QEvent*) + 424
39 0x7f466a43f945 QAbstractButton::mouseReleaseEvent(QMouseEvent*) + 213
38 0x7f466a43f77a /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libQt5Widgets.so.5(+0x23f77a) [0x7f466a43f77a]
37 0x7f466a43e45a /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libQt5Widgets.so.5(+0x23e45a) [0x7f466a43e45a]
36 0x7f466a43e272 QAbstractButton::clicked(bool) + 50
35 0x7f4667aab1ea QMetaObject::activate(QObject*, int, int, void**) + 1850
34 0x7f466943468f pqPythonShell::runScript() + 1695
33 0x7f4669432a9a pqPythonShell::executeScript(QString const&) + 506
32 0x7f4664a0671e vtkPythonInteractiveInterpreter::RunStringWithConsoleLocals(char const*) + 46
31 0x7f465c808bcc PyRun_StringFlags + 332
30 0x7f465c7c331b PyEval_EvalCode + 27
29 0x7f465c7c32ee PyEval_EvalCodeEx + 62
28 0x7f465c7c32a2 _PyEval_EvalCodeWithName + 82
27 0x7f465c7c2f09 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x1c2f09) [0x7f465c7c2f09]
26 0x7f465c66e750 _PyEval_EvalFrameDefault + 24720
25 0x7f465c6682a7 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x682a7) [0x7f465c6682a7]
24 0x7f465c667187 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x67187) [0x7f465c667187]
23 0x7f465c66dd2d _PyEval_EvalFrameDefault + 22125
22 0x7f465c6bd2d1 _PyFunction_Vectorcall + 177
21 0x7f465c7c2f09 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x1c2f09) [0x7f465c7c2f09]
20 0x7f465c66e750 _PyEval_EvalFrameDefault + 24720
19 0x7f465c6682a7 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x682a7) [0x7f465c6682a7]
18 0x7f465c6c0be3 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0xc0be3) [0x7f465c6c0be3]
17 0x7f465c667187 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x67187) [0x7f465c667187]
16 0x7f465c66e750 _PyEval_EvalFrameDefault + 24720
15 0x7f465c6682a7 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x682a7) [0x7f465c6682a7]
14 0x7f465c6c0be3 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0xc0be3) [0x7f465c6c0be3]
13 0x7f465c667187 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x67187) [0x7f465c667187]
12 0x7f465c66e750 _PyEval_EvalFrameDefault + 24720
11 0x7f465c66830b /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x6830b) [0x7f465c66830b]
10 0x7f465c6bd4ee _PyObject_MakeTpCall + 158
9 0x7f465c71850b /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libpython3.9.so.1.0(+0x11850b) [0x7f465c71850b]
8 0x7f45502b15a1 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/lib/python3.9/site-packages/paraview/modules/vtkRemotingServerManager.so(+0xb15a1) [0x7f45502b15a1]
7 0x7f466634a84b vtkSMInputProperty::AddInputConnection(vtkSMProxy*, unsigned int) + 427
6 0x7f465bfb68f9 /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libvtkCommonCore-pv5.10.so.1(+0x5b68f9) [0x7f465bfb68f9]
5 0x7f466638ce2b vtkObject::vtkClassMemberCallback<vtkSMProperty>::operator()(vtkObject*, unsigned long, void*) + 59
4 0x7f4666387323 vtkSMProperty::UpdateDomains() + 67
3 0x7f4666308369 vtkSMArrayListDomain::Update(vtkSMProperty*) + 217
2 0x7f466630791d /home/philipp/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin/../lib/libvtkRemotingServerManager-pv5.10.so.1(+0x10791d) [0x7f466630791d]
1 0x7f466b42997d /lib/x86_64-linux-gnu/libc.so.6(+0x19d97d) [0x7f466b42997d]
0 0x7f466b2ce520 /lib/x86_64-linux-gnu/libc.so.6(+0x42520) [0x7f466b2ce520]
( 163.489s) [paraview ] :0 FATL| Signal: SIGSEGV
Can anyone help me?
