I ran this SPH example in LS-DYNA (https://www.dynaexamples.com/sph/intermediate-examples/wavestructure) and it generated the d3plotxx outputs.
I was able to read into Paraview the .k LS-DYNA keyword file and it created the associated .lsdyna XML file and was able to read the first d3plot file, but not any of the subsequent others.
I am able to post-process the run without issue using both LS-PrePost and also Hyperview.
I am interested in wanting to post-process this run in Paraview because I recently learned about Paraview via DualSPHysics and I want to be able to compare the results from the LS-DYNA run agains the results from DualSPHysics.
The specific error that I get is that when it tries to open d3plot01, Paraview says that it doesn’t recognize the data/format and wants me to select the appropriate reader.
And this is true regardless of whether I set the file type to LS-DYNA when I open the file or not.
I’ve also tried to rename all of the d3plotxx files to d3plotxx.d3plot to see if that would help and it didn’t.
Any suggestions/advice would be greatly appreciated.
Thank you.
