I have a set of Python plugin data sources which works great separately. When two different data sources created MacOS ParaView crashes sometimes. Here is the plugin code: https://github.com/mobigroup/ParaView-plugins/blob/master/NCube/NCubeParaViewPlugin.py
/Applications/ParaView-5.7.0.app/Contents/MacOS/paraview
Loguru caught a signal: SIGSEGV
Stack trace:
64 0x7fff6ddc53d5 start + 1
63 0x1084d3f70 main + 592
62 0x109516092 QCoreApplication::exec() + 402
61 0x1095116f2 QEventLoop::exec(QFlags<QEventLoop::ProcessEventsFlag>) + 418
60 0x11be9444d qt_plugin_instance + 127181
59 0x7fff3f451588 -[NSApplication run] + 699
58 0x7fff3f45746b -[NSApplication(NSEvent) _nextEventMatchingEventMask:untilDate:inMode:dequeue:] + 1361
57 0x7fff3f45877d _DPSNextEvent + 1135
56 0x7fff410c0c76 _BlockUntilNextEventMatchingListInModeWithFilter + 64
55 0x7fff410c0ded ReceiveNextEventCommon + 355
54 0x7fff410c11ab RunCurrentEventLoopInMode + 292
53 0x7fff41e6266e CFRunLoopRunSpecific + 455
52 0x7fff41e62d65 __CFRunLoopRun + 1189
51 0x7fff41e6379b __CFRunLoopDoSources0 + 195
50 0x7fff41e7fdd9 __CFRunLoopDoSource0 + 108
49 0x7fff41e7fe33 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 17
48 0x11be95651 qt_plugin_instance + 131793
47 0x108e3336b QWindowSystemInterface::sendWindowSystemEvents(QFlags<QEventLoop::ProcessEventsFlag>) + 155
46 0x108e4c122 QGuiApplicationPrivate::processMouseEvent(QWindowSystemInterfacePrivate::MouseEvent*) + 2962
45 0x10951599f QCoreApplication::notifyInternal2(QObject*, QEvent*) + 159
44 0x10885de1f QApplication::notify(QObject*, QEvent*) + 383
43 0x10885cb02 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 306
42 0x1088b5779 QDesktopWidget::qt_metacall(QMetaObject::Call, int, void**) + 4649
41 0x1088b6b1c QDesktopWidget::qt_metacall(QMetaObject::Call, int, void**) + 9676
40 0x10885d430 QApplicationPrivate::sendMouseEvent(QWidget*, QMouseEvent*, QWidget*, QWidget*, QWidget**, QPointer<QWidget>&, bool) + 896
39 0x10951599f QCoreApplication::notifyInternal2(QObject*, QEvent*) + 159
38 0x10885f89d QApplication::notify(QObject*, QEvent*) + 7165
37 0x10885cb02 QApplicationPrivate::notify_helper(QObject*, QEvent*) + 306
36 0x109ff6e1e QVTKOpenGLNativeWidget::event(QEvent*) + 30
35 0x109ffae52 QVTKRenderWindowAdapter::handleEvent(QEvent*) + 50
34 0x109ff57f3 QVTKInteractorAdapter::ProcessEvent(QEvent*, vtkRenderWindowInteractor*) + 3939
33 0x10e7ecdf5 vtkSubjectHelper::InvokeEvent(unsigned long, void*, vtkObject*) + 981
32 0x10e61b1e1 vtkCallbackCommand::Execute(vtkObject*, unsigned long, void*) + 33
31 0x10ac656c3 vtkPVInteractorStyle::OnMouseMove() + 147
30 0x10ac74c76 vtkPVTrackballRotate::OnMouseMove(int, int, vtkRenderer*, vtkRenderWindowInteractor*) + 998
29 0x10e7ecdf5 vtkSubjectHelper::InvokeEvent(unsigned long, void*, vtkObject*) + 981
28 0x10a17121b vtkSMViewProxyInteractorHelper::Render() + 331
27 0x10a16e1ff vtkSMViewProxy::InteractiveRender() + 191
26 0x10a66c017 vtkPVSessionBase::ExecuteStream(unsigned int, vtkClientServerStream const&, bool) + 55
25 0x10a66e9c5 vtkPVSessionCore::ExecuteStream(unsigned int, vtkClientServerStream const&, bool) + 85
24 0x10a66ec94 vtkPVSessionCore::ExecuteStreamInternal(vtkClientServerStream const&, bool) + 276
23 0x10bcce33d vtkClientServerInterpreter::ProcessStream(vtkClientServerStream const&) + 61
22 0x10bcce610 vtkClientServerInterpreter::ProcessOneMessage(vtkClientServerStream const&, int) + 688
21 0x10bccf0aa vtkClientServerInterpreter::ProcessCommandInvoke(vtkClientServerStream const&, int) + 346
20 0x10bcd0496 vtkClientServerInterpreter::CallCommandFunction(char const*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&) + 374
19 0x10f9d86b3 vtkPVRenderViewCommand(vtkClientServerInterpreter*, vtkObjectBase*, char const*, vtkClientServerStream const&, vtkClientServerStream&, void*) + 2019
18 0x10a2d120c vtkPVRenderView::InteractiveRender() + 188
17 0x10a2d1c1e vtkPVRenderView::Render(bool, bool) + 2526
16 0x10c8c408e vtkGenericOpenGLRenderWindow::Render() + 62
15 0x10c9217de vtkOpenGLRenderWindow::Render() + 14
14 0x10d2ccd9c vtkRenderWindow::Render() + 332
13 0x10d2ccefc vtkRenderWindow::DoStereoRender() + 172
12 0x10d2db5a9 vtkRendererCollection::Render() + 137
11 0x10d2d5142 vtkRenderer::Render() + 1122
10 0x10d2d5706 vtkRenderer::AllocateTime() + 294
9 0x10d27078a vtkFrustumCoverageCuller::Cull(vtkRenderer*, vtkProp**, int&, int&) + 282
8 0x10ac67fdf vtkPVLODActor::GetBounds() + 63
7 0x10d2c06f9 vtkPolyDataMapper::GetBounds() + 153
6 0x10c8ab2f9 vtkCompositePolyDataMapper2::ComputeBounds() + 153
5 0x10d26213d vtkCompositeDataDisplayAttributes::ComputeVisibleBounds(vtkCompositeDataDisplayAttributes*, vtkDataObject*, double*) + 77
4 0x10d262352 vtkCompositeDataDisplayAttributes::ComputeVisibleBoundsInternal(vtkCompositeDataDisplayAttributes*, vtkDataObject*, vtkBoundingBox*, bool) + 434
3 0x10d2623af vtkCompositeDataDisplayAttributes::ComputeVisibleBoundsInternal(vtkCompositeDataDisplayAttributes*, vtkDataObject*, vtkBoundingBox*, bool) + 527
2 0x10dfdf076 vtkDataSet::GetBounds(double*) + 22
1 0x10e14a5ff vtkPolyData::ComputeBounds() + 367
0 0x7fff6dfe881f unw_resume + 10
( 68.128s) [paraview ] :0 FATL| Signal: SIGSEGV
Segmentation fault: 11
