MacOS ParaView 5.8.1-RC1 scipy issue
ERROR: In /Users/kitware/dashboards/buildbot-slave/9f496ada/source-paraview/VTK/Filters/Python/vtkPythonAlgorithm.cxx, line 112
vtkPythonAlgorithm (0x600000100820): Failure when calling method: "ProcessRequest":
  File "/usr/local/lib/python3.7/site-packages/xarray/core/missing.py", line 506, in _get_interpolator_nd
    from scipy import interpolate
  File "/Applications/ParaView-5.8.1-RC1-994-g5af6d421a1.app/Contents/Python/scipy/interpolate/__init__.py", line 175, in <module>
    from .interpolate import *
  File "/Applications/ParaView-5.8.1-RC1-994-g5af6d421a1.app/Contents/Python/scipy/interpolate/interpolate.py", line 20, in <module>
    import scipy.linalg
  File "/Applications/ParaView-5.8.1-RC1-994-g5af6d421a1.app/Contents/Python/scipy/linalg/__init__.py", line 190, in <module>
    from .misc import *
  File "/Applications/ParaView-5.8.1-RC1-994-g5af6d421a1.app/Contents/Python/scipy/linalg/misc.py", line 5, in <module>
    from .blas import get_blas_funcs
  File "/Applications/ParaView-5.8.1-RC1-994-g5af6d421a1.app/Contents/Python/scipy/linalg/blas.py", line 214, in <module>
    from scipy.linalg import _fblas
ImportError: dlopen(/Applications/ParaView-5.8.1-RC1-994-g5af6d421a1.app/Contents/Python/scipy/linalg/_fblas.cpython-37m-darwin.so, 2): Symbol not found: _main
  Referenced from: /Applications/ParaView-5.8.1-RC1-994-g5af6d421a1.app/Contents/Python/scipy/linalg/_fblas.cpython-37m-darwin.so
  Expected in: flat namespace
 in /Applications/ParaView-5.8.1-RC1-994-g5af6d421a1.app/Contents/Python/scipy/linalg/_fblas.cpython-37m-darwin.so
During handling of the above exception, another exception occurred:
  File "/Applications/ParaView-5.8.1-RC1-994-g5af6d421a1.app/Contents/Python/vtkmodules/util/vtkAlgorithm.py", line 152, in ProcessRequest
    return vtkself.ProcessRequest(request, inInfo, outInfo)
  File "/Applications/ParaView-5.8.1-RC1-994-g5af6d421a1.app/Contents/Python/vtkmodules/util/vtkAlgorithm.py", line 198, in ProcessRequest
    return self.RequestData(request, inInfo, outInfo)
  File "/Users/mbg/Documents/focal/ParaView-plugins/NCube/NCubeImageOnTopographyBlockSource.py", line 110, in RequestData
    image = image.interp_like(dem)
  File "/usr/local/lib/python3.7/site-packages/xarray/core/dataarray.py", line 1420, in interp_like
    other, method=method, kwargs=kwargs, assume_sorted=assume_sorted
  File "/usr/local/lib/python3.7/site-packages/xarray/core/dataset.py", line 2723, in interp_like
    return ds.interp(numeric_coords, method, assume_sorted, kwargs)
  File "/usr/local/lib/python3.7/site-packages/xarray/core/dataset.py", line 2635, in interp
    variables[name] = missing.interp(var, var_indexers, method, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/xarray/core/missing.py", line 626, in interp
    var.transpose(*original_dims).data, x, destination, method, kwargs
  File "/usr/local/lib/python3.7/site-packages/xarray/core/missing.py", line 680, in interp_func
    func, kwargs = _get_interpolator_nd(method, **kwargs)
  File "/usr/local/lib/python3.7/site-packages/xarray/core/missing.py", line 508, in _get_interpolator_nd
    raise ImportError("Interpolation with method `%s` requires scipy" % method)
ImportError: Interpolation with method `linear` requires scipy
ERROR: In /Users/kitware/dashboards/buildbot-slave/9f496ada/source-paraview/VTK/Common/ExecutionModel/vtkExecutive.cxx, line 753
vtkPVCompositeDataPipeline (0x600000e5baa0): Algorithm vtkPythonAlgorithm(0x600000100820) returned failure for request: vtkInformation (0x60000284a4c0)
  Debug: Off
  Modified Time: 1997319
  Reference Count: 2
  Registered Events: (none)
  Request: REQUEST_DATA
  FROM_OUTPUT_PORT: 0
  ALGORITHM_AFTER_FORWARD: 1
  FORWARD_DIRECTION: 0
The issue is the same as on paraView 5.7 with Python 2 - all compiled libraries in ParaView package unusable:
>>> from scipy.interpolate import interp1d
  File "<console>", line 1, in <module>
    import scipy.linalg
    from .misc import *
