Making plugin's panel invisible programmatically
Dear PV devs,
How do I make a panel of a plugin invisible within c++?
By panel I mean <PropertyGroup> which has a name and several properties.
So far, I have tried calling hide() and setVisibility(false), to no effect.
I have also tried to find how the “panel_visibiliy” is implemented in the code and I found no related methods.
Thank you for your help.
Sincerely,
Art
You need to use hide() on the widget instance. Make sure you are calling it on the right object.
