As you know, if I want to use mathematical expressions/symbols in the axis titles, the font of the axis title (inside or outside of the $$ signs) is converted to the default font of matplotlib (DejaVu Sans). My problem comes out here. I am using non-ASCII characters (mostly extended ASCII chars, Turkish language) in the axis title (outside of the $ signs) so default font type doesn’t support non-ASCII chars.
My questions are:
Can I change default font type when MathText is used? If possible, how?
Can I use ASCII codes or utf-8 unicode in the axis title when MathText is used? If possible, how?
If you are talking about Line Chart Axis Title or similar, there is a font control in the advanced options that allows you to select a specific font file.
No. I am aware of title font control but when the MathText is used, font control is disabled. You can easily test it by typing a text/symbol between the $$ signs in the chart axis title. If you know a way to activate the font control when the MathText is used, I will be satisfied.
