Hello there, could someone help me to fix a problem related with the version of matplotlib that ParaView installed in my ubuntu machine? I have installed paraview using sudo command, and when i tried to run another code that uses matplotlib, it’s always appearing:
,Python
UserWarning: Unable to import Axes3D. This may be due to multiple versions of Matplotlib being installed (e.g. as a system package and as a pip package). As a result, the 3D projection is not available.
warnings.warn("Unable to import Axes3D. This may be due to multiple versions of "
And i have the 3.8.2 version that i installed using pip. As the version of matplotlib installed by ParaView is 3.5, it’s causing the conflict of versions and i’m having problems to plot graphs and I also cannot plot 3d plots. What should I do to fix it?
