I have a 11 GB vti file that is taking forever to open in version 5.9.1 on Windows with MPI on. After 2 hours I killed the process and tried the latest nightly version without MPI but it was stuck, too. An older one, 5.2, says that it does not recognise the file format, however, we have produced the vti file with the same code as hundreds of other times. I can show the header of the vti file but due to its size it is unreasonable to try sharing it in any way, I believe.
<?xml version="1.0"?>
<VTKFile type="ImageData" version="0.1" byte_order="LittleEndian">
<ImageData WholeExtent=" 0 680 0 680 0 400 " Origin=" -17.000000000000000 -17.000000000000000 -10.000000000000000 " Spacing=" 5.0000000000000003E-002 5.0000000000000003E-002 5.0000000000000003E-002 ">
<Piece Extent=" 0 680 0 680 0 400 ">
<PointData Scalars="scalars">
<DataArray Name="vectors" type="Float64" NumberOfComponents="3" Format="ascii">
0.000000E+00 0.000000E+00 0.000000E+00
The end of the file is also sane
0.000000E+00
0.000000E+00
0.000000E+00
0.000000E+00
0.000000E+00
0.000000E+00
</CellData>
</Piece>
</ImageData>
</VTKFile>
Best regards,
Maria
