I am adding and deleting sphere source with resolution 80000, and open memory inspector to monitor the memory change, i found the memory is increasing all the time…
What i expect is the memory should not increase after i delete the source
Using this script (2.0 KB) as a macro, I was able to reproduce the behavior for the first 10 spheres, 10Mb of memory by sphere, but it then stops increasing.
Do you see the same behavior ?
This should not happen ideally, but not critical imo.
I wonder if this has to do with ParaView’s memory handling code. I believe i was told that ParaView doesn’t “return” memory that it uses to the system, but it does know when it’s free, and adds it to the free memory pool to be used. An example where this works correctly, but is really confisuing, is remote server if you open something large, delete it, and open something large a second time. The big no-no is memory should never grow until we crash. And, from Mathieu;s experiments, sounds like it doesn’t.
