I’m looking to read binary data based on example 13.2.4 in the paraview guide, but I seem to be running into a memory leak with the code I’ve adapted below. When I activate my virtualenv and run the script using pvpython, memory usage grows without bounds until I manually kill the process or the os does it for me. The data set consists of 19 files of 262144 “longs” (times 5 scalar variables) - I don’t think it should be consuming 50GB+ of memory. See attached screenshot for output from activity monitor:
from paraview.simple import (
_DisableFirstRenderCameraReset,
GetRenderView,
ProgrammableSource,
Render,
Show,
_DisableFirstRenderCameraReset()
request_info = """
# Activate the virtualenv with necessary packages
activate_this = '/Users/jslawitsky/Desktop/research/venv/bin/activate_this.py'
execfile(activate_this, dict(__file__=activate_this))
import numpy
import yaml
with open("/Users/jslawitsky/Desktop/research/sample/input/config.yaml", "r") as fp:
config = yaml.load(fp)
outInfo.Set(
executive.WHOLE_EXTENT(),
0, config["grid_points.x"] - 1,
0, config["grid_points.y"] - 1,
0, config["grid_points.z"] - 2,
outInfo.Set(
vtk.vtkDataObject.SPACING(),
config["domain_size.x"] / config["grid_points.x"],
config["domain_size.y"] / config["grid_points.y"],
config["domain_size.z"] / (config["grid_points.z"] - 1),
outInfo.Set(
vtk.vtkDataObject.ORIGIN(),
0,
0,
(config["domain_size.z"] / (config["grid_points.z"] - 1)) / 2,
outInfo.Remove(executive.TIME_STEPS())
start = config["output.instantaneous.skip"] * config["time_step_size"]
stop = config["number_of_time_steps"] * config["time_step_size"]
step = config["output.instantaneous.frequency"] * config["time_step_size"]
for timestep in numpy.linspace(start, stop, (stop - start) / step):
outInfo.Append(executive.TIME_STEPS(), timestep)
outInfo.Remove(executive.TIME_RANGE())
outInfo.Append(executive.TIME_RANGE(), config["output.instantaneous.skip"])
outInfo.Append(executive.TIME_RANGE(), config["number_of_time_steps"])
request_data = """
activate_this = "/Users/jslawitsky/Desktop/research/venv/bin/activate_this.py"
import numpy
import os
import yaml
from distutils.util import strtobool
from vtk.numpy_interface import algorithms as algs
from vtk.numpy_interface import dataset_adapter as dsa
scalars = {"p", "u", "v", "w"}
if strtobool(config["output.instantaneous.write_eddy_viscosity"]):
scalars.add("nu_t")
ts = outInfo.Get(executive.TIME_STEPS())
if outInfo.Has(executive.UPDATE_TIME_STEP()):
t = int(outInfo.Get(executive.UPDATE_TIME_STEP()))
else:
print "no update time available"
t = 0
exts = [executive.UPDATE_EXTENT().Get(outInfo, i) for i in xrange(6)]
nbfiles = (
(config["number_of_time_steps"] - config["output.instantaneous.skip"]) /
dims = [
exts[1] - exts[0] + 1,
exts[3] - exts[2] + 1,
exts[5] - exts[4] + 1,
output.SetExtent(exts)
data = numpy.empty(dims[0] * dims[1] * dims[2] * nbfiles, dtype=numpy.dtype('<f'))
points_per_step = (
config["grid_points.x"] *
config["grid_points.y"] *
dir_name = "/Users/jslawitsky/Desktop/research/sample/output/instantaneous-fields/"
def AddScalarVariable(nbfiles, varname):
for i in xrange(nbfiles):
# example file format: 'dir_name/p-001.bin'
fname = "{}{}-{}.bin".format(dir_name, varname, str(i).zfill(3))
with open(fname, "rb") as fp:
fp.seek(0)
begin = points_per_step * i
end = points_per_step * (i + 1)
data[begin:end] = numpy.fromfile(fp, dtype=numpy.dtype("<f"), count=-1, sep="")
output.PointData.append(data, varname)
for varname in scalars:
output.GetInformation().Set(output.DATA_TIME_STEP(), t)
View1 = GetRenderView()
pSource1 = ProgrammableSource()
pSource1.OutputDataSetType = 'vtkImageData'
pSource1.ScriptRequestInformation = request_info
pSource1.Script = request_data
pSource1.UpdatePipelineInformation()
Show(pSource1, View1)
Render()
When I comment out output.PointData.append(data, varname), the code runs to completion, but nothing is displayed (obviously because I haven’t appended any data).
Any insights would be greatly appreciated.
Thanks,
Jon
