If there are two files the “Load State File” recongnize the correct filename ,for example “d:\example_3b.pvsm’, the Green arrow display the filename in windows system
If there are multiple files the “preview load State” could not display all the filename correctly, as red arrow point out, it should be ‘example_3b.pvsm’ ,but here it is ‘example_…b.pvsm’
At present I could load in the State file with manually input correct filename ‘example_3b.pvsm’
If Load State File function could display the correct filename, it will be much better for easy handling much more files.
