Hi everybody,
I have a tridimensional domain (a cylinder) of a scalar field. The case represents flow over an airfoil. After taking a slice of it (a plane parallel to the two cylinder’s faces and passing to the midpoint cylinder axis) and plotting the 2-D resulting scalar field, it seems data is missing around the airfoil flow
Plotting the wireframe it seems there are missing cell/data points after the slice, some suggestions ? Thank you
Edit :
The case is a Fluent solution converted to Encase format.
I tried also with the latest Paraview 5.8 and the following error appears as I try to slice the 3D set
Generic Warning: In /home/buildslave/dashboards/buildbot/paraview-pvbinsdash-linux-shared-release_superbuild/build/superbuild/paraview/src/VTK/Common/DataModel/vtkPolyhedron.cxx, line 1320
The polyhedron is not watertight or non-manifold because the number of faces of edge 175-171 is not 2 but 1
