Missing python's stdlib modules in Paraview 6.1.0
I tried to use some python’s stdlib in Paraview 6.1.0, but it failed to import.
>>> import tomllib
  File "<console>", line 1, in <module>
ModuleNotFoundError: No module named 'tomllib'
For example, tomllib is included in Python >= 3.11, and Paraview 6.1.0 uses Python 3.12.7
>>> import sys
>>> sys.version
'3.12.7 (tags/v3.12.7:0b05ead, Oct  1 2024, 03:06:41) [MSC v.1941 64 bit (AMD64)]'
Is that ok?
PS: others libraries seems to be ok.
>>> import os
>>> import sys
>>> import dataclasses
>>> import argparse
Yep…that should be addressed. Is there a canonical list of stdlib modules/packages we can check against?
I’m not sure, but I run the following snippet:
import sys
import importlib
from pprint import pprint
missing = []
working = []
for name in sys.stdlib_module_names:
    try:
        importlib.import_module(name)
        working.append(name)
    except Exception:
        missing.append(name)
print("Working:", len(working))
print("Missing:", len(missing))
print("Missing modules:")
pprint(sorted(missing))
And the result is:
Working: 265
Missing: 36
Missing modules:
['_aix_support',
 '_crypt',
 '_curses',
 '_curses_panel',
 '_dbm',
 '_gdbm',
 '_posixshmem',
 '_posixsubprocess',
 '_pydatetime',
 '_pylong',
 '_scproxy',
 '_ssl',
 '_tkinter',
 'crypt',
 'curses',
 'fcntl',
 'graphlib',
 'grp',
 'idlelib',
 'msilib',
 'nis',
 'ossaudiodev',
 'posix',
 'pty',
 'pwd',
 'readline',
 'resource',
 'spwd',
 'ssl',
 'syslog',
 'termios',
 'tkinter',
 'tomllib',
 'tty',
 'turtle',
 'turtledemo']
Perhaps this could help.
See this merge request adding a test to keep our modules-to-package list in-sync.
https://gitlab.kitware.com/paraview/common-superbuild/-/merge_requests/749
