To understand the issue, let’s take a look at a typical Unstructured Grid blueprint for specifying data arrays associated with points.
coordsets:
coords0:
type: "explicit"
values:
x: [....]
y: [....]
z: [....]
topologies:
mesh0:
coordset: "coords0"
elements:
shape: "..."
connectivity: [......]
fields:
field_vertex0:
association: "vertex"
topology: "mesh0"
As we notice, when specifying fields, one has to specify topology which points to a named topology.
Immediately, we run into some ambiguities in definition. When specifying field_vertex0 array, what order are the tuples specified in? The implementation in VTK/ParaView assumes the order to be same as the order in which the coords are specified.
If all point locations specified in coordsets/coords0 are indeed used in topology/mesg0 then this seems reasonable. But there’s no requirement that coords0 can’t have extra point locations specified. In fact, in case of codes like Exodus, ICON, multiple topology patches reference same vertex coordinates. So here’s how the mesh may look in such case:
coordsets:
coordsAll:
type: "explicit"
values:
x: [....]
y: [....]
z: [....]
topologies:
mesh0:
coordset: "coordsAll"
elements:
shape: "..."
mesh1:
elements:
shape: "..."
fields:
field_vertex0:
topology: "mesh0"
Now, the field_vertex0 definition becomes even more dubious. Should I repeat it for each toplogy/mesh*? Should I only specify it once? What happens if I have multiple coordsets?
To avoid all this ambiguity, I propose we extend the blueprint to add support for specifying a coordset instead of topology for a field e.g.
fields:
field_vertex0:
association: "vertex" # only vertex can be specified here.
coordset: "<coordset name>"
field_element0:
association: "element" # association "vertex" should be deprecated
topology: "<topology name>"
