I have some vtk files with point data and I want to modify data over some points (changing values or may be multiplying by some factor). After modifying I want to save this as a new .vtk again. Is there a way of doing this in python or paraview. The number of points are very large (120k and even more). An example file is here.
solution0000000001.vtk (824.0 KB)
Filters->Calculator
File → SaveData
Thank you for your reply. How to use the calculator filter to access specific points of an array? Doesn’t it deal with the whole array?
I attached an example vtk file here.
solution0000007600.zip (896.3 KB)
Yes
If you want to do an actual specific computation, then you should use a programmable filter.
