ModuleNotFoundError: No module named 'paraview'
(base) rameshkolluru@lichfield:~$ pvpython
pvpython      pvpython3.10
(base) rameshkolluru@lichfield:~$ pvpython3.10
hwloc/linux: Ignoring PCI device with non-16bit domain.
Pass --enable-32bits-pci-domain to configure to support such devices
(warning: it would break the library ABI, don't enable unless really needed).
Python 3.10.4 (main, Jun 29 2022, 12:14:53) [GCC 11.2.0] on linux
Type "help", "copyright", "credits" or "license" for more information.
>>> from paraview.simple import *
  File "<stdin>", line 1, in <module>
I am trying to run script generated by paraview trace option… when I use pvpython I am getting the following
can anyone help me
Hi @Ramesh_Kolluru ,
How do you install paraview/pvpython ?
Paraview I had installed using the default package manager in popos.
Please try with our binary release: https://www.paraview.org/download/?version=v5.10&filter=Linux
What would be the difference between them? Could you please elaborate why this issue is popping out?
Our binary release works.
Thats a question for popos package managers.
I tired installing from binaires but it fails at this point with the following error… can you help how to get out with this
  • Up-to-date: /opt/paraview-5.10.1/install/lib/cmake/llvm/./FindSphinx.cmake
    [ 77%] Completed ‘llvm’
    [ 78%] Built target llvm
    [ 79%] Built target glproto-download
    [ 79%] Built target glproto-update
    [ 79%] Built target glproto-patch
    [ 79%] Built target expat-download
    [ 79%] Built target expat-update
    [ 79%] Built target expat-patch
    [ 80%] Built target expat
    [ 80%] Built target pythonmako-download
    [ 80%] Built target pythonmako-update
    [ 81%] Built target pythonmako-patch
    [ 82%] Built target pythonmako
    [ 83%] Built target ninja-download
    [ 83%] Built target ninja-update
    [ 83%] Built target ninja-patch
    [ 83%] Built target meson-download
    [ 83%] Built target meson-update
    [ 84%] Built target meson-patch
    [ 85%] Built target meson
    [ 85%] Built target mesa-download
    [ 85%] Built target mesa-update
    [ 85%] Built target mesa-patch
    [ 85%] Performing configure step for ‘mesa’
    The Meson build system
    Version: 0.60.3
    Source dir: /opt/paraview-5.10.1/superbuild/mesa/src
    Build dir: /opt/paraview-5.10.1/superbuild/mesa/src/build
    Build type: native build
    Program python found: YES (/opt/paraview-5.10.1/install/bin/python)
    Project name: mesa
    Project version: 21.2.1
    C compiler for the host machine: cc (gcc 11.2.0 “cc (Ubuntu 11.2.0-19ubuntu1) 11.2.0”)
    C linker for the host machine: cc ld.bfd 2.38
    C++ compiler for the host machine: c++ (gcc 11.2.0 “c++ (Ubuntu 11.2.0-19ubuntu1) 11.2.0”)
    C++ linker for the host machine: c++ ld.bfd 2.38
    Host machine cpu family: x86_64
    Host machine cpu: x86_64
    Dependency clang (modules: clangBasic, clangCodeGen, clangDriver, clangFrontend, clangFrontendTool, clangHandleCXX, clangHandleLLVM) skipped: feature microsoft-clc disabled
    Program python3 found: YES (/opt/paraview-5.10.1/install/bin/python3)
    Fetching value of define “ETIME” : 62
    Checking for function “bswap32” : YES
    Checking for function “bswap64” : YES
    Checking for function “clz” : YES
    Checking for function “clzll” : YES
    Checking for function “ctz” : YES
    Checking for function “expect” : YES
    Checking for function “ffs” : YES
    Checking for function “ffsll” : YES
    Checking for function “popcount” : YES
    Checking for function “popcountll” : YES
    Checking for function “unreachable” : YES
    Checking for function “types_compatible_p” : YES
    Compiler for C supports function attribute const: YES
    Compiler for C supports function attribute flatten: YES
    Compiler for C supports function attribute malloc: YES
    Compiler for C supports function attribute pure: YES
    Compiler for C supports function attribute unused: YES
    Compiler for C supports function attribute warn_unused_result: YES
    Compiler for C supports function attribute weak: YES
    Compiler for C supports function attribute format: YES
    Compiler for C supports function attribute packed: YES
    Compiler for C supports function attribute returns_nonnull: YES
    Compiler for C supports function attribute alias: YES
    Compiler for C supports function attribute noreturn: YES
    Compiler for C supports function attribute visibility:hidden: YES
    Checking if “__uint128_t” : compiles: YES
    Compiler for C supports arguments -Werror=implicit-function-declaration: YES
    Compiler for C supports arguments -Werror=missing-prototypes: YES
    Compiler for C supports arguments -Werror=return-type: YES
    Compiler for C supports arguments -Werror=empty-body: YES
    Compiler for C supports arguments -Werror=incompatible-pointer-types: YES
    Compiler for C supports arguments -Werror=int-conversion: YES
    Compiler for C supports arguments -Wimplicit-fallthrough: YES
    Compiler for C supports arguments -Werror=thread-safety: NO
    Compiler for C supports arguments -Wno-missing-field-initializers: YES
    Compiler for C supports arguments -Wno-format-truncation: YES
    Compiler for C supports arguments -fno-math-errno: YES
    Compiler for C supports arguments -fno-trapping-math: YES
    Compiler for C supports arguments -Qunused-arguments: NO
    Compiler for C supports arguments -fno-common: YES
    Compiler for C supports arguments -Werror=format: YES
    Compiler for C supports arguments -Wformat-security: YES
    Compiler for C++ supports arguments -Werror=return-type: YES
    Compiler for C++ supports arguments -Werror=empty-body: YES
    Compiler for C++ supports arguments -Wno-non-virtual-dtor: YES
    Compiler for C++ supports arguments -Wno-missing-field-initializers: YES
    Compiler for C++ supports arguments -Wno-format-truncation: YES
    Compiler for C++ supports arguments -fno-math-errno: YES
    Compiler for C++ supports arguments -fno-trapping-math: YES
    Compiler for C++ supports arguments -Qunused-arguments: NO
    Compiler for C++ supports arguments -flifetime-dse=1: YES
    Compiler for C++ supports arguments -Werror=format: YES
    Compiler for C++ supports arguments -Wformat-security: YES
    Compiler for C supports arguments -Wno-override-init: YES
    Compiler for C supports arguments -Wno-initializer-overrides: NO
    Compiler for C supports arguments -Werror=pointer-arith: YES
    Compiler for C++ supports arguments -Werror=pointer-arith: YES
    Compiler for C supports arguments -Werror=gnu-empty-initializer: NO
    Compiler for C++ supports arguments -Werror=gnu-empty-initializer: NO
    Compiler for C supports arguments -Wmicrosoft-enum-value: NO
    Checking if “GCC atomic builtins” : compiles: YES
    Checking if “GCC atomic builtins required -latomic” : links: YES
    Checking if “GCC 64bit atomics” with dependency not-found: links: YES
    Library ws2_32 found: NO
    Header <sys/sysmacros.h> has symbol “major” : YES
    Header <sys/sysmacros.h> has symbol “minor” : YES
    Header <sys/sysmacros.h> has symbol “makedev” : YES
    Header <sys/mkdev.h> has symbol “major” : NO
    Check usable header “sched.h” : YES
    Checking for function “sched_getaffinity” : YES
    Check usable header “xlocale.h” : NO
    Check usable header “linux/futex.h” : YES
    Check usable header “endian.h” : YES
    Check usable header “dlfcn.h” : YES
    Check usable header “execinfo.h” : YES
    Check usable header “sys/shm.h” : YES
    Check usable header “cet.h” : YES
    Check usable header “pthread_np.h” : NO
    Checking for function “strtof” : YES
    Checking for function “mkostemp” : YES
    Checking for function “timespec_get” : YES
    Checking for function “memfd_create” : YES
    Checking for function “random_r” : YES
    Checking for function “flock” : YES
    Checking for function “strtok_r” : YES
    Checking for function “getrandom” : YES
    Checking for function “qsort_r” : YES
    Checking for function “qsort_s” : NO
    Header <errno.h> has symbol “program_invocation_name” : YES
    Checking for function “posix_memalign” : YES
    Checking whether type “struct dirent” has member “d_type” : YES
    Checking if “strtod has locale support” : links: YES
    Checking if “Bsymbolic” : links: YES
    Checking if “gc-sections” : links: YES
    Checking if “version-script” : links: YES
    Checking if “dynamic-list” : links: YES
    Compiler for C supports link arguments -Wl,–build-id=sha1: YES
    Checking for function “dlopen” : YES
    Checking for function “dladdr” with dependency not-found: YES
    Checking for function “dl_iterate_phdr” : YES
    Checking for function “clock_gettime” : YES
    Found pkg-config: /usr/bin/pkg-config (0.29.2)
    Run-time dependency zlib found: YES 1.2.11
    Found CMake: /usr/bin/cmake (3.22.1)
    Run-time dependency libzstd found: NO (tried pkgconfig and cmake)
    Run-time dependency threads found: YES
    Checking for function “pthread_setaffinity_np” with dependency threads: YES
    Run-time dependency expat found: YES 2.4.1
    Library m found: YES
    Run-time dependency libdrm found: NO (tried pkgconfig and cmake)
    WARNING: Ignoring LLVM CMake dependency because dynamic was requested
    llvm-config found: YES (/opt/paraview-5.10.1/install/bin/llvm-config) 7.0.0
    Run-time dependency LLVM (modules: bitwriter, core, engine, executionengine, instcombine, mcdisassembler, mcjit, native, scalaropts, transformutils, coroutines) found: YES 7.0.0
    Run-time dependency valgrind found: NO (tried pkgconfig)
    Program bison found: YES (/usr/bin/bison)
    Program bison found: YES 3.8.2 (/usr/bin/bison)
    Program flex found: YES (/usr/bin/flex)
    Run-time dependency libunwind found: NO (tried pkgconfig and cmake)
    Run-time dependency OpenMP found: YES 4.5
    Run-time dependency x11 found: NO (tried pkgconfig and cmake)
meson.build:1952:4: ERROR: Dependency “x11” not found, tried pkgconfig and cmake
A full log can be found at /opt/paraview-5.10.1/superbuild/mesa/src/build/meson-logs/meson-log.txt
CMake Error at /opt/paraview-5.10.1/superbuild/sb-mesa-configure.cmake:47 (message):
Failed with exit code 1
make[2]: *** [superbuild/CMakeFiles/mesa.dir/build.make:99: superbuild/mesa/stamp/mesa-configure] Error 1
make[1]: *** [CMakeFiles/Makefile2:8674: superbuild/CMakeFiles/mesa.dir/all] Error 2
make: *** [Makefile:136: all] Error 2
(base) rameshkolluru@lichfield:/opt/paraview-5.10.1$
This looks like a configuration/build log.
Please state exactly what are you trying to do with ParaView.
I was trying to install paraview from the binaries as told … I had downloaded the tar file extracted it and when I was installing it with make that error popped out.
Binaries do not need to be built. please do the following.
I tried this and then tried using the procedure explained … paraview worked but if I have to run a python script using pvpython it again returns the same module not found error
(base) rameshkolluru@lichfield:~/Downloads/ParaView-5.10.1-MPI-Linux-Python3.9-x86_64/bin$ pvpython
./pvpython instead of pvpython, you are using your local install.
Thank you it worked … how would I make these default, should I use alias in bashrc or is there anyother way … could you please help me
Regards
  1. Remove your local installation of paraview (and report an issue to popos ?)
  2. Put the folder in /opt/
  3. Add /opt/ParaView…/bin to your PATH
