I am trying to port my application to a different platform but when I run it the error code is returning as 3 from catalyst initialization routine.
200: catalyst debug: search path from default list: `/work2/noaa/nems/tufuk/COP/spack-stack-1.9.1/envs/cop/install/oneapi/2024.2.1/libcatalyst-2.0.0-xhbiy3w/lib64/catalyst`
200: catalyst debug: trying to load `/work2/noaa/nems/tufuk/COP/spack-stack-1.9.1/envs/cop/install/oneapi/2024.2.1/libcatalyst-2.0.0-xhbiy3w/lib64/catalyst/libcatalyst-paraview.so`: invalid
It seems that 3 means catalyst_status_error_not_found but I could not find more information about the error message. I double check by setting export CATALYST_DEBUG=1 in my job and confirmed that libcatalyst-paraview.so is in the correct path. I wonder if you have any suggestion to debug the issue? I also tried to set export PARAVIEW_LOG_CATALYST_VERBOSITY="INFO" but I think the code is not reaching to ParaView level. So, I am not getting any more information.
Just to update if I set export CATALYST_IMPLEMENTATION_NAME="stub" then it picks the stub implementation under catalyst installation and works. But, if I set to paraview then it tries to get it from paraview installation directory and does not accept it by saying invalid. I am not sure what is looking for to sat valid or invalid at this point. I installed all packages with same compiler etc.
I also set export CATALYST_IMPLEMENTATION_NAME=“vtk” and it picked the shared library from paraview installation and passed the initialization without any error.
Sorry if this is an obvious answer. Did you confirm that your ParaView has Catalyst? You should be able to see the libcatalyst-paraview.so in $PARAVIEW_ROOT/lib/catalyst/. It’s weird that you can pickup the vtk implementation but not the ParaView one. Also, try setting $CATALYST_IMPLEMENTATION_PATH (I’m typing from memory, so double check the actual spelling).
@ben.boeckel Thanks for help. I think #127 is not merged yet. Right? Maybe I could give a try when it is available to get more information.
@Alexandre_Minotlibcatalyst-paraview.so is in my installation directory but somehow the code does not pick it up and says invalid. I also tried by setting CATALYST_IMPLEMENTATION_PATHS (I was adding it to the node before) and it did not help. So, probably the issue is in somewhere else.
@ben.boeckel Okay. I run it in my end with catalyst master. Here is the output. The extra information is returning no error which seems strange. I also confirmed that the file is in the indicated location. Any idea?
200: catalyst debug: trying to load `/work2/noaa/nems/tufuk/COP/spack-stack-1.9.1/envs/cop/install/oneapi/2024.2.1/paraview-5.13.1-uwaer47/lib64/catalyst/libcatalyst-paraview.so`: invalid ((no error))
200: catalyst debug: search path from default list: `/work2/noaa/nems/tufuk/COP/spack-stack-1.9.1/envs/cop/install/oneapi/2024.2.1/libcatalyst-master-jvhtiov/lib64/catalyst`
200: catalyst debug: trying to load `/work2/noaa/nems/tufuk/COP/spack-stack-1.9.1/envs/cop/install/oneapi/2024.2.1/libcatalyst-master-jvhtiov/lib64/catalyst/libcatalyst-paraview.so`: invalid ((no error))
BTW, I have no libcatalyst-paraview.so under libcatalyst-master-jvhtiov but I think since it is not accepting the one in paraview installation directory, it automatically tries to find the one from catalyst directory. So, it should be fine.
Note how it’s looking for paraview catalyst in the catalyst stub folder instead of in the paraview folder. I see this when the ParaView environment is not set correctly. Just to be safe, I would triple check your environment. Make sure that your LD_LIBRARY_PATH has $PARAVIEW_ROOT/lib64.
@ben.boeckel Okay. It produces lots of output. Is there anything that I need to look at. The last thing before trying to load libcatalyst-paraview.so is the EGL libraries.
@ben.boeckel I am seeing following in the log - (RPATH from file /work2/noaa/nems/tufuk/COP/spack-stack-1.9.1/envs/cop/install/oneapi/2024.2.1/paraview-5.13.1-uwaer47/lib64/catalyst/libcatalyst-paraview.so). Maybe there is something wrong with this and it create confusion. Not sure.
There’s no mention of the path of interest beyond the RPATH thing? Usually an error is mentioned somewhere…unless something fundamentally makes the library ineligible. Is it the right architecture?
Before 200: catalyst debug: trying to load /work2/noaa/nems/tufuk/COP/spack-stack-1.9.1/envs/cop/install/oneapi/2024.2.1/paraview-5.13.1-uwaer47/lib64/catalyst/libcatalyst-paraview.so: invalid ((no error)) log output, I have only log related with RPATH. I don’t think it is an architecture issue since vtk is working fine which is shipped with same ParaView installation but let me check more carefully.
I could run same setup in terms of installation and simulation case with different platform using GPU nodes and EGL setup successfully. It uses same compiler but different MPI implementation. So, maybe I could compare the differences to find out the issue.
