MSB8066 error while compiling the paraview 5.12.0
while compiling 5.12.0, the following is my command.
1.cmake -G"Visual Studio 16 2019" -T host="x64" -A "x64" -DPARAVIEW_USE_PYTHON=ON -DPARAVIEW_USE_MPI=ON -DCMAKE_BUILD_TYPE=Release -DCMAKE_PREFIX_PATH='D:\Qt\5.15.2\msvc2019_64\lib\cmake\Qt5' -DPARAVIEW_ENABLE_WEB=ON -DPARAVIEW_BUILD_LEGACY_REMOVE=ON ..\paraview
2.cmake --build ./ -j 2 --config Release
3.MSB8066 errors occur
 Generating Python wrapper sources for vtkWebGLDataSet
C:\Program Files (x86)\Microsoft Visual Studio\2019\Community\MSBuild\Microsoft\VC\v160\Microsoft.CppCommon.targets(241
,5): error MSB8066: “D:\new\brain-visualization\pvb\CMakeFiles\a728aaf97a240a039fc47f852a75858c\vtkObjectIdMapPython.cx
x.rule;D:\new\brain-visualization\pvb\CMakeFiles\a728aaf97a240a039fc47f852a75858c\vtkRemoteInteractionAdapterPython.cxx
.rule;D:\new\brain-visualization\pvb\CMakeFiles\a728aaf97a240a039fc47f852a75858c\vtkWebApplicationPython.cxx.rule;D:\ne
w\brain-visualization\pvb\CMakeFiles\a728aaf97a240a039fc47f852a75858c\vtkWebInteractionEventPython.cxx.rule;D:\new\brai
n-visualization\pvb\CMakeFiles\a728aaf97a240a039fc47f852a75858c\vtkWebUtilitiesPython.cxx.rule;D:\new\brain-visualizati
on\pvb\CMakeFiles\a728aaf97a240a039fc47f852a75858c\vtkWebCoreModulePython.cxx.rule;D:\new\brain-visualization\pvb\CMake
Files\08eb037f33f89c16c2b5111eb2d5c0e6\vtkWebCorePythonInit.cxx.rule”的自定义生成已退出,代码为 1。 [D:\new\brain-visualization\pvb\v
tkWebCorePython.vcxproj]
,5): error MSB8066: “D:\new\brain-visualization\pvb\CMakeFiles\1400951957b9a37ab31e3a06c0167778\vtkWebGLDataSetPython.c
xx.rule;D:\new\brain-visualization\pvb\CMakeFiles\1400951957b9a37ab31e3a06c0167778\vtkWebGLExporterPython.cxx.rule;D:\n
ew\brain-visualization\pvb\CMakeFiles\1400951957b9a37ab31e3a06c0167778\vtkWebGLObjectPython.cxx.rule;D:\new\brain-visua
lization\pvb\CMakeFiles\1400951957b9a37ab31e3a06c0167778\vtkWebGLPolyDataPython.cxx.rule;D:\new\brain-visualization\pvb
\CMakeFiles\1400951957b9a37ab31e3a06c0167778\vtkWebGLWidgetPython.cxx.rule;D:\new\brain-visualization\pvb\CMakeFiles\14
00951957b9a37ab31e3a06c0167778\vtkWebGLExporterModulePython.cxx.rule;D:\new\brain-visualization\pvb\CMakeFiles\c1129b69
5f01b11672fb228db3109a9a\vtkWebGLExporterPythonInit.cxx.rule”的自定义生成已退出,代码为 1。 [D:\new\brain-visualization\pvb\vtkWebGLE
xporterPython.vcxproj]
I do not see any error in that log
the error code is MSB8066
This means that the associated custom command failed. Is there any output related to wrapping vtkWebGLExporter near here?
