I am trying to show my simulation in ParaView. I am using the multimesh protocol as my data is organized hierarchically. However, I can’t see anything ParaView. The dataset I received is completely empty.
My conduit node looks like this, which I think its correct
catalyst:
channels:
garments:
type: "multimesh"
data:
Garments_0_Piece_0:
coordsets:
coords:
type: "explicit"
values:
x: []
y: []
z: []
topologies:
mesh:
type: "unstructured"
coordset: "coords"
elements:
shape: "polygonal"
connectivity: []
sizes: []
offsets: []
assembly:
Garments:
0:
Pieces:
0: "Garments_0_Piece_0"
state:
timestep: 223
time: 0.223000273108482
time:
timestep:
cycle: 223
I have removed the x,y,z, size, offset and connectivity datasets for clarity
However, in ParaView, I dont receive the assembly or the meshes. I just receive an empty PartionedDataSet.
My python script is supersimple, basically does nothing
# script-version: 2.0
# Catalyst state generated using paraview version 5.12.0-RC2
import paraview
paraview.compatibility.major = 5
paraview.compatibility.minor = 12
#### import the simple module from the paraview
from paraview.simple import *
#### disable automatic camera reset on 'Show'
# setup views used in the visualization
# setup view layouts
# create a new 'STL Reader'
untitledstl = TrivialProducer(registrationName='garments')
# restore active source
SetActiveSource(untitledstl)
# Catalyst options
from paraview import catalyst
options = catalyst.Options()
options.GlobalTrigger = 'Time Step'
options.EnableCatalystLive = 1
options.CatalystLiveURL = 'host.docker.internal:22222'
options.CatalystLiveTrigger = 'Time Step'
if __name__ == '__main__':
from paraview.simple import SaveExtractsUsingCatalystOptions
# Code for non in-situ environments; if executing in post-processing
# i.e. non-Catalyst mode, let's generate extracts using Catalyst options
SaveExtractsUsingCatalystOptions(options)
Is there something wrong with this setup? I can’t spot anything wrong…
