Hello. I am using Paraview 5.5.2 and I am looking for some advice on how to filter out cells with negative volumes.
I discovered that some cells had negative volumes when using the Integrate Variables filter on a positive quantity and received a negative result.
My filter chain is the following:
[input data]
CellSize Filter
Threshold Filter -> Volume -> minimum 0.
The problem that I am encountering is that the resulting selection does not look correct. In fact, it looks like it is keying off of a different scalar value in the dataset than volume.
I renamed the volume array output of the CellSize filter to a new name and set the Threshold filter to key off of that new name just in case that was the issue, but I got the same result.
Clearly I am missing something. Is there a better way to eliminate negative volume cells? Is there a quick diagnostic that can be used to determine if negative volume cells exist?
Thank you in advance for your help,
-A
