Negative cells volume while reading Fluent .cas file
I would like to load a Fluent .cas file using Fluent case reader in paraview. After loading the file, it appears that the mesh contains elements with negative volume (I checked this with the Cell Size filter). Let me just add that “Check mesh” in Fluent returns all positive volumes and no problems with the mesh.
The elements with negative volume belong to the boundary layer. In the image below, I have overlapped the original mesh and the Cell Size filter after the treshold operation (I am displaying only cells with negative volume). You can see that the problem is with prismatic cells.
Has anyone experienced similar behavior before? Maybe there is a simple way to remedy it?
Please share your data.
I prepared a smaller case on which the same thing happens.
test_geometry.cas (2.5 MB)
Localization of cells with negative volume:
Treshold and isolate cells with negative volume:
I hope its enough
please share the .dat file too.
Consistency of the volume of the Wedge element seems to involve complications, but the most immediate fix would be to modify the following two lines in the PopulateWedgeCell() function in vtkFLUENTReader.cxx.
  if (this->Faces->value[base].c0 == i)
 → if (this->Faces->value[base].c1 == i)
and
  if (this->Faces->value[top].c1 == i)
 → if (this->Faces->value[top].c0 == i)
Note: The same modifications will be needed for vtkFLUENTCFFReader, which follows the vtkFLUENTReader implementation.
Thanks for the answers
I’ll try to do the same from the code level with the modifications Kyoshimi suggested and let you know if I succeeded
Ok that’s the problem. I bet you are initializing the simulation with a steady solution (previously calculated with a steady solver). Don’t do that. In the steady solver create an .ip file (file/interpolate/write-data). At the beginning of the FSI simulation read this ip file to initialize your simulation
