I am working with a 4D (x,y,z,t) Netcdf file (winds from a reanalysis). I like to make an animation of the 3D wind field in time. Paraview reads the time as hours since 1900. I like to annotate time in the animation as Month and Year rather than hours since 1900. I have tried all kind of possibilities using" Annotate Time Filter" and also using the “NETCDFTimeAnnotation” plug-in. Using the latter one, I get the following error message:
File "<string>", line 22, in <module>
File "<string>", line 28, in RequestData
UnboundLocalError: local variable 'hasCftime' referenced before assignment
Need the python cftime (or the older netcdftime) module for the NetCDFTimeAnnotation plugin!
Failed to evaluate expression '"On %02i.%02i.%02i at %02i:%02i" % (Date[0], Date[1], Date[2], Date[3], Date[4])'. The following exception stack should provide additional developer specific information. This typically implies a malformed expression. Verify that the expression is valid.
Variables in current scope are ['input', 'time_value', 't_value', 'time_steps', 't_steps', 'time_range', 't_range', 'time_index', 't_index', 'time_units', 'time_calendar', 'u_units', 'v_units', 'w_units', 'RawDate']
File "/Applications/ParaView-5.10.1.app/Contents/Python/paraview/detail/annotation.py", line 95, in execute
result = calculator.compute(inputs, expression, ns=ns)
File "/Applications/ParaView-5.10.1.app/Contents/Python/paraview/detail/calculator.py", line 146, in compute
retVal = eval(subEx, globals(), mylocals)
File "<string>", line 1, in <module>
NameError: name 'Date' is not defined
Any help will be much appreciated. Many thanks in advance.
