New SyntaxWarnings appear with Python 3.8
New SyntaxWarning for ‘is’ with literals starting with Python 3.8
It currently works by accident in coprocessing by produces a number of these warnings:
/home/olearypatrick/code/ParaView/lib/python3.7/site-packages/paraview/coprocessing.py:859: SyntaxWarning: "is not" with a literal. Did you mean "!="?
  if root_directory is not '' and not root_directory.endswith("/"):
/home/olearypatrick/code/ParaView/lib/python3.7/site-packages/paraview/coprocessing.py:866: SyntaxWarning: "is" with a literal. Did you mean "=="?
  if self.__RootDirectory is "":
/home/olearypatrick/code/ParaView/lib/python3.7/site-packages/paraview/tpl/cinema_python/adaptors/paraview/pv_introspect.py:198: SyntaxWarning: "is" with a literal. Did you mean "=="?
  if proxy['parent'] is '0' and numberOfProducers > 0:
/home/olearypatrick/code/ParaView/lib/python3.7/site-packages/paraview/detail/exportnow.py:17: SyntaxWarning: "is not" with a literal. Did you mean "!="?
  if rd is not '' and not rd.endswith("/"):
/home/olearypatrick/code/ParaView/lib/python3.7/site-packages/paraview/detail/exportnow.py:24: SyntaxWarning: "is not" with a literal. Did you mean "!="?
  if self.__RootDirectory is not '':
/home/olearypatrick/code/ParaView/lib/python3.7/site-packages/paraview/detail/exportnow.py:32: SyntaxWarning: "is not" with a literal. Did you mean "!="?
/home/olearypatrick/code/ParaView/lib/python3.7/site-packages/paraview/detail/exportnow.py:76: SyntaxWarning: "is not" with a literal. Did you mean "!="?
  if self.__RootDirectory is not '' and not os.path.exists(self.__RootDirectory):
/home/olearypatrick/code/ParaView/lib/python3.7/site-packages/paraview/detail/exportnow.py:179: SyntaxWarning: "is not" with a literal. Did you mean "!="?
/home/olearypatrick/code/ParaView/lib/python3.7/site-packages/paraview/detail/exportnow.py:181: SyntaxWarning: "is not" with a literal. Did you mean "!="?
  if root_directory is not '' and not os.path.exists(root_directory):
/home/olearypatrick/code/ParaView/lib/python3.7/site-packages/paraview/detail/exportnow.py:274: SyntaxWarning: "is not" with a literal. Did you mean "!="?
  if not ssp.HasAnnotation("enabled") or not (ssp.GetAnnotation("enabled") is '1'):
Patrick, would you mind creating an issue in the issue tracker for this?
done 20086
