So I finished my superbuild with the following command:
➜ build-paraview cmake -DCMAKE_INSTALL_PREFIX=/home/qth20/.local/paraview -DENABLE_mesa=True -DENABLE_paraview:BOOL=ON -DENABLE_ffmpeg:BOOL=ON -DENABLE_tbb:BOOL=ON -DENABLE_ospray:BOOL=ON ../paraview-superbuild
➜ build-paraview make -j 8
[... Several minutes later...]
-- Set runtime path of "/home/qth20/Downloads/build-paraview/install/lib/pvrenderserver" to "/home/qth20/Downloads/build-paraview/install/lib"
-- Installing: /home/qth20/Downloads/build-paraview/install/bin/pvrenderserver
-- Installing: /home/qth20/Downloads/build-paraview/install/lib/pvbatch
-- Set runtime path of "/home/qth20/Downloads/build-paraview/install/lib/pvbatch" to "/home/qth20/Downloads/build-paraview/install/lib"
-- Installing: /home/qth20/Downloads/build-paraview/install/bin/pvbatch
-- Installing: /home/qth20/Downloads/build-paraview/install/lib/pvpython
-- Set runtime path of "/home/qth20/Downloads/build-paraview/install/lib/pvpython" to "/home/qth20/Downloads/build-paraview/install/lib"
-- Installing: /home/qth20/Downloads/build-paraview/install/bin/pvpython
[ 95%] Fixing paths in generated CMake files for packaging.
[ 96%] Completed 'paraview'
[ 98%] Built target paraview
Scanning dependencies of target paraviewsdk
[ 98%] Creating directories for 'paraviewsdk'
[100%] No download step for 'paraviewsdk'
[100%] No update step for 'paraviewsdk'
[100%] No patch step for 'paraviewsdk'
[100%] No configure step for 'paraviewsdk'
[100%] No build step for 'paraviewsdk'
[100%] No install step for 'paraviewsdk'
[100%] Completed 'paraviewsdk'
[100%] Built target paraviewsdk
But, inside install/bin, there is no paraview:
➜ build-paraview ls install/bin | grep paraview
paraview-config
2to3 fc-scan llvm-dis llvm-size python2
bugpoint fc-validate llvm-dlltool llvm-split python2.7
bunzip2 ffmpeg llvm-dsymutil llvm-stress python2.7-config
bzcat FileCheck llvm-dwarfdump llvm-strings python2-config
bzcmp freetype-config llvm-dwp llvm-symbolizer python-config
bzdiff gperf llvm-extract llvm-tblgen sancov
bzegrep idle llvm-lib llvm-xray sanstats
bzfgrep ispc llvm-link nc-config smTestDriver
bzgrep libpng16-config llvm-lto not smtpd.py
bzip2 libpng-config llvm-lto2 obj2yaml verify-uselistorder
bzip2recover llc llvm-mc opt vtkkwProcessXML-pv5.5
bzless lli llvm-mcmarkup paraview-config vtkParseJava-pv5.5
bzmore lli-child-target llvm-modextract pip vtkWrapClientServer-pv5.5
count llvm-ar llvm-mt pip2 vtkWrapHierarchy-pv5.5
easy_install llvm-as llvm-nm pip2.7 vtkWrapJava-pv5.5
easy_install-2.7 llvm-bcanalyzer llvm-objdump pngfix vtkWrapPythonInit-pv5.5
embree2 llvm-cat llvm-opt-report png-fix-itxt vtkWrapPython-pv5.5
f2py llvm-config llvm-pdbutil pvbatch xml2-config
fc-cache llvm-cov llvm-PerfectShuffle pvdataserver xmlcatalog
fc-cat llvm-c-test llvm-profdata pvpython xmllint
fc-list llvm-cvtres llvm-ranlib pvrenderserver xmlwf
fc-match llvm-cxxdump llvm-readelf pvserver yaml2obj
fc-pattern llvm-cxxfilt llvm-readobj pydoc yaml-bench
fc-query llvm-diff llvm-rtdyld python
Am I doing something fundamentally wrong…?
