[I think I just deleted my post, so if not, this will be a duplicate posting. (I’m having quite a bit of difficulty with Discourse this evening – twice it thought I wanted to “abandon” my posting, and then lost the draft! Maybe 4th time is the charm.]
I’m experimenting with a simple Python plugin that uses vtkThreshold but constrains the low and high values to a particular delta. The issue I’m having is that unlike the standard “Threshold” filter in ParaView, my simple plugin only outputs the point data, but not the cell data.
I think the most obvious consequence of this is that with the output from the ParaView built-in filter, I can render a Volume representation, whereas with my plugin, there is no option to render as a Volume.
I Googled around a bit, but wasn’t able to determine what the problem might be. One hypothesis I have is that the built-in filter may convert the point data to cell data after doing the processing.
Here’s my simple script, I used the Contour-Shrink example as my starting point, and I’ll add property parameters later, once I figure out my problem – or really once with the aid of the ParaView community, the problem is solved.
# Synchronized Threshold plugin (From ContourShrink example)
from vtkmodules.util.vtkAlgorithm import VTKPythonAlgorithmBase
from paraview.util.vtkAlgorithm import smproxy, smproperty, smdomain
import vtk # Note: added to ContourShrink example to make it work
@smproxy.filter(label="Threshold Sync")
@smproperty.input(name="Input")
@smdomain.datatype(dataTypes=["vtkDataSet"], composite_data_supported=False)
class ThresholdSync(VTKPythonAlgorithmBase):
def __init__(self):
VTKPythonAlgorithmBase.__init__(self)
print "Loading Sync'd Threshold plugin"
inp = vtk.vtkDataSet.GetData(inInfo[0])
opt = vtk.vtkPolyData.GetData(outInfo)
th = vtk.vtkThreshold()
th.SetInputData(inp)
print "number of point arrays " + str(inp.GetPointData().GetNumberOfArrays())
print "number of cell arrays " + str(inp.GetCellData().GetNumberOfArrays())
print "point data range: " + str(inp.GetPointData().GetArray(0).GetRange())
th.ThresholdBetween(130.0, 150.0)
th.Update() # Note: Update() not available in the Python Shell
opt.ShallowCopy(th.GetOutput())
return 1
I’m using the Wavelet source as the input with all default settings.
Thanks in advance, Bill
