no python in ParaView 5.6.0
Dear All,
I have the problem, that the python console, programmable filter is not working in ParaView-5.6.0-MPI-Windows-msvc2015-64bit, ParaView-5.6.0-Windows-msvc2015-64bit, that I have downloaded from the ParaView website.
Switching on the Python Shell, I get the following message:
File “”, line 1, in
File “C:/Users/somogyib/KTM/software/installed/ParaView-5.6.0-MPI-Windows-msvc2015-64bit/bin\Lib/site-packages\paraview\simple.py”, line 41, in
from paraview import servermanager
File “C:/Users/somogyib/KTM/software/installed/ParaView-5.6.0-MPI-Windows-msvc2015-64bit/bin\Lib/site-packages\paraview\servermanager.py”, line 3278, in
__initialize()
File “C:/Users/somogyib/KTM/software/installed/ParaView-5.6.0-MPI-Windows-msvc2015-64bit/bin\Lib/site-packages\paraview\servermanager.py”, line 3269, in __initialize
c = Connection(iter.GetCurrentSessionId(), iter.GetCurrentSession())
File “C:/Users/somogyib/KTM/software/installed/ParaView-5.6.0-MPI-Windows-msvc2015-64bit/bin\Lib/site-packages\paraview\servermanager.py”, line 1979, in init
_createModules(self.Modules)
File “C:/Users/somogyib/KTM/software/installed/ParaView-5.6.0-MPI-Windows-msvc2015-64bit/bin\Lib/site-packages\paraview\servermanager.py”, line 2622, in _createModules
m.filters = createModule(‘filters’)
File “C:/Users/somogyib/KTM/software/installed/ParaView-5.6.0-MPI-Windows-msvc2015-64bit/bin\Lib/site-packages\paraview\servermanager.py”, line 2723, in createModule
cobj = _createClass(groupName, proxyName, apxm=pxm)
File “C:/Users/somogyib/KTM/software/installed/ParaView-5.6.0-MPI-Windows-msvc2015-64bit/bin\Lib/site-packages\paraview\servermanager.py”, line 2667, in _createClass
if (prop.GetInformationOnly() and propName != “TimestepValues” )
AttributeError: ‘NoneType’ object has no attribute ‘GetInformationOnly’
Do you know what might be the problem?
Thanks in advance!
With Best Regards,
Bence Somogyi
Found the solution now. The ParaView settings file (more about it here: https://www.paraview.org/Wiki/ParaView_Settings_Files) got somehow corrupted. After removing the file called ParaView5.8.0.ini (yes, the pyhon shell problem occured also with the newer version of PV) file, the python shell works again.
