Node set displaying
Hello. i have a set of nodes in my exodus file. Tell me please: what filter i need to use, to display it as a glyph?
tree
Did you try the Glyph filter ?
Are you sure you have selected the node sets in the Properties panel? Node sets will show up in the assembly as empty blocks even if they are not loaded.
Screen Shot 2023-11-07 at 9.21.22 AM
Thank you @Kenneth_Moreland , but after adding glyph all nodes are displayed, not only those which are in the set. May be i need some additional filter between .e file and the glyph?
Local_Axis frame2.pvsm (1.1 MB)
If you only want the data in the node sets, then unselect all the blocks and sets that you don’t want in the Properties panel.
I want to leave visible both line elements an node sets.
You can load the file twice. In one reader, load the blocks with the line elements. In the other reader, load the node sets. Then attach the Glyph filter to the reader loading the node sets.
Alternately, you can have one reader loading both (as you do now) and then use the Extract Block Screen Shot 2023-11-07 at 11.48.01 AM filter to extract the node set blocks.
Thank you. Extract Block is what i needed
