Non-uniform rectilinear grid isses
I am trying to render a non-uniform rectilinear grid with catalyst.
The code I use to generate the grid is:
    mesh["coordsets/coords/type"] = "rectilinear";
    mesh["coordsets/coords/values/x"] = grid.g_x;
    mesh["coordsets/coords/values/y"] = grid.g_y;
    mesh["coordsets/coords/values/z"] = grid.g_z;
    mesh["topologies/mesh/coordset"] = "coords";
    mesh["topologies/mesh/type"] = "rectilinear";
    mesh["topologies/mesh/elements/origin/i"] = grid.g_x[0];
    mesh["topologies/mesh/elements/origin/j"] = grid.g_y[0];
    mesh["topologies/mesh/elements/origin/k"] = grid.g_z[0];
calling mesh[“coordsets/coords/values”].print(); gives the following:
  "x":
    "dtype":"float64",
    "number_of_elements": 31,
    "offset": 0,
    "stride": 8,
    "element_bytes": 8,
    "endianness": "little",
    "value": [0.0, 1.0, 2.0, 3.0, 4.0, 5.0, 6.0, 7.0, 8.0, 9.0, 10.0, 11.0, 12.0, 13.0, 14.0, 15.0, 16.0, 17.0, 18.0, 19.0, 20.0, 21.0, 22.0, 23.0, 24.0, 25.0, 26.0, 27.0, 28.0, 29.0, 30.0]
  "y":
    "dtype":"float64",
    "number_of_elements": 8,
    "offset": 0,
    "stride": 8,
    "element_bytes": 8,
    "value": [-1.0, -0.6, 0.0, 1.0, 2.0, 3.0, 3.6, 4.0]
  "z":
    "dtype":"float64",
    "offset": 0,
    "stride": 8,
    "element_bytes": 8,
This for some reason results in a uniform grid in Paraview, with an origin at {0,0,0}.
How can I properly render the non-uniform rectilinear grid?
The file I use for catalyst is the one from Lulesh:
savedata.py (578 Bytes)
Thanks in advance!
Not entirely sure but your issue might be related to this. What version of ParaView are you using?
Unexpected plot shown by ParaView Catalyst on using Rectilinear Conduit blueprint - In Situ Support - ParaView
