I am new to this powerful software and I am trying to do my first calculation. Data is x,y,z grid of points and over the whole x,y range i would like to calculate RMS for a given z interval. Can you guide me with a walkthrough?
I can even settle for a max, or mean of the z interval, as long as I get a single z value at the end.
Is there a place to better understand the buttons in the calculation box, possibly through examples?
thank you
If you have not seen it, you might want to check out the Extract Subset to first extract the volume of interest (VOI) region of values that you want to compute on first. Doing that will make it easier to apply subsequent filters that compute the statistics you want.
You can use the Descriptive Statistics filter to compute basic statistics like mean, min, max, and some more. I don’t think it computes RMS, but you could use the Calculator filter to first square the field to get the mean square.
I think adding the Python Calculator with the expression sqrt(mean(fieldname*fieldname)) (replacing fieldname with the actual name of the field) will compute the RMS. The filter will stupidly repeat the RMS on every point of your data, but you can easily see the value in the Information tab.
Using the Descriptive Statistics I get single values, but I am looking for a map.
I used Python Calculator and got the same volume returned to me with one value using the expression “mean(fieldname)” just to keep it simple. Below you can see my data has x,y,z dimension and I want to calculate the mean of all points in the z space “0 to 255 (dimension: 256)”. Should be a map. What am I missing, and thank you for your previous reply and help.
0 to 18 (dimension: 19)
0 to 1,023 (dimension: 1,024)
Um, I’m not sure I understand what you are trying to do. Are you trying to convert your 19x1024x256 dataset to a 19x1024 dataset with an RMS (or other aggregate) over all the z values at that x,y?
There is no real mechanism to do that in ParaView. You might be able to play some tricks with animating a VOI and then doing temporal statistics. But ultimately, this sounds like it requires special coding in a Programmable Filter.
Yep, you got what I am trying to accomplish. Thanks for giving it a try, I am coming from a seismic interpretation background and RMS is something done often. I will have to work with what I have or do some serious data gymnastics
